My car is a 1987 Toyota Tercel DX Wagon RHD 1452cc manual driven car.
Stabilizer bar of my car was removed for a replacement of the lower arm bushings. I could notice that the to sides of the bar are not symmetrical. It should have bent for the time.
I did bent it to gain the symmetrical shape. But I have a doubt its shape could have been changed.
So I need a photograph of such a car stabilizer bar to check it.
I did search in the internet but couldnt find.
If someone can provide me a photograph of a such stabilizer bar it is a great help.
Request for a picture of a Stabilizer bar
Re: Request for a picture of a Stabilizer bar
I do not have any to photograph for you, but I have had them out of the car before and as i recall the rear bar is symmetrical. I can take a picture of one mounted in a car that is jacked in the air. I have my daily drive on jacks all pulled apart for a rebuild, and can snap a few pictures for you.
- ALiveSR5
This is from a 1985 Tercel 4WD wagon - don't know how similar or different it is, as compared to one for a 1987.
- Dumindu
Thank you very much ALiveSR5 for the picture.
This is enough for me to figure out. Thank you Petros for yor willing to take some pictures.
My one is same as yours. I have traced your image as follows
After I bent the bar now it is as follows. I marked the the change in blue.
Before I bent the bar, BLUE-BLACK angle at the end was around 25 degrees in right and 15 degrees in left. It was the cause for the unsymmetrical nature. I bent the both of them up to 5 degrees.
My lower control arm bushing collar is oriented towards the rear now. Before the bent, it was towards the front. If it is oriented towards front, previous shape before the bent is easy to install. But if the collar is towards rear, present shape is easy to install. Is your lower control arm bushing collar is towards front or back? (it should be towards back as in FSM)
- ALiveSR5
You are welcome - glad it helped.
In your other post about the bushings, the photos show their correct orientation. Petros also made an interesting point about them, too.
As I was told, the stabilizer bar is made of spring steel and should not be heated or welded with a torch, because it will ruin the temper and make it useless or dangerous to use.
So, I am not understanding how yours got bent, as you described, unless it has weakened from rusting or heating it.
Because the stabilizer is spring steel and designed to stabilize, I understand that it is very difficult to install - some people have used ratchet straps to pull the ends together enough so it will fit into the control arms, for assembly.
the sway bars are all identical in all years of Tercel4wd. it could get bent in an accident, it can be bent back. it would be a lot of effort, some kind of jig to hold it down, and a very long pipe over the end to bend it into position.
- ALiveSR5
What I was getting from his description was that the bar was not bent but he assumed that the ends should easily fit into the control arms, without effort, instead of squeezing/pulling the ends inward, with some kind of ratchet strap or something, to make it fit.
From his drawings, it looks like he bent the bar ends inward, somehow, to make it fit without pulling the ends inward. Having done that, it would appear that the tension of the bar would be somewhat lost, thus reducing the effectiveness of the bar, maybe?
I do not know enough about this to offer anything more.
unless he and you understand the word "symmetrical" differently, this is what he wrote in the first post:
" I could notice that the to sides of the bar are not symmetrical. It should have bent for the time.
I did bent it to gain the symmetrical shape. But I have a doubt its shape could have been changed."
I assume this means one side was not symmetrical with the other. that could happen in an accident, or even striking a curb too hard on one side when parking. so he bent it back, but appears to be concerned now that the shape is correct.
