Orientation of the lower control arm bushing?
Dumindu
Post by Dumindu »
My car is a 1987 Toyota Tercel DX Wagon RHD 1452cc manual driven car.
I have a doubt which should be the direction of the lower control arm. Problem aroused when I replacing the bush. A mechanic had put the rubber collar of the bush towards the front. But my car is not comfortable when driving.
Doubt aroused because this collar should absorb the forward pushing power of the rear wheels. So It should be directed towards back.
Whether rubber collar of the bushing directed towards front or back?
ALiveSR5
My tercel:: Was a stock 1985, SR5, 4WD, 6-speed manual, Wagon.
Re: Orientation of the lower control arm bushing?
Post by ALiveSR5 »
Dumindu wrote: Thu Feb 04, 2021 10:20 am Whether rubber collar of the bushing directed towards front or back?
These photos are for a 1985 4WD SR5 Wagon but they may help answer your question:
Left control arm - back view
Left arm bushing close-up back view
Left arm bushing close-up front view
Right control arm - back view
Right arm bushing close-up back view
Right arm bushing close-up front view
Hopefully, looking at the arms then comparing the bushing close-ups, you will be able to confirm proper direction.
No other vehicle that I have ever owned had a heart and soul like my 1985 Tercel SR5 4WD Wagon. :D
Great minds may think alike but it is the doers who see their visions become reality. :?
Dumindu
Post by Dumindu »
Thank you for your advice.
But according to the Service Manual diagrams it should be directed to opposite side?
I do not think it matters much, it is completely captured in the mount.
I do not even see the reason for it having the extra external rubber, the "teeth" on the metal sleeve are supposed to bight the mount on the frame of the car so it does not rotate, so the movement is all with the rubber part of the bushing. I can not see how having the flange on the bushing forward or aft will make any difference in operation.
The Professor
Post by The Professor »
There are two possibilities:
1) The Toyota engineers used an off-the-shelf bushing for the lower control arm location.
2) This bushing was specifically designed for this location on this application.
In either case, I believe the rubber collar was oriented that way for a reason (though we may not know what that reason was). If it had no purpose, it would have been cheaper (in case #2) to specify a bushing without a collar. This would reduce tooling complexity, component weight, and reduce the overall vehicle cost, which is a big consideration manufacturers take into account that the general public isn't privy to.
If it was an off-the-shelf bushing chosen to reduce cost (in case #1), it probably was originally designed as a rotating suspension bushing, and for the same reasoning above, I would expect the design engineers wouldn't include unnecessary tooling cost and part complexity without some justification. Unless the Tercel design engineers were ultra lazy (they don't appear to have been!) and spec'ed this for no reason other than it fit the ID, OD, and width of the control arm. They essentially chose to assemble the entire car using aircraft bolts, which is not a lazy, or price-adverse design decision.
I'd say orient the bushings as shown in the FSM diagrams.
The Professor wrote: Mon Feb 08, 2021 10:13 am There are two possibilities:
this bushing is used elsewhere, on the rear suspension in fact (panhard rod, perhaps also on the upper rear axle links),and in other models. so I tend to think it was a standard bushing in their inventory. They tend to use bushings and other small parts across the product line, sometimes in odd places (front suspension parts in the rear in other models, and visa-versa). though I would agree that I would not second guess what the original design intent was, it is best to get it as the factory installed it.
but OTOH, having worked in the industry, sometimes the factory has reasons irrelevant to the home wrencher (like faster automated assembly), or sometimes a decisions is made at random because it makes no difference. the first gen MR2 rear brake rotor is the same part as the front 2nd gen Tercel brake rotor. the front and rear ball joints on the first gen MR2 is the same on the 2nd gen front Tercel, and likely the same year corolla and almost certainly other models.
