Fenders
Als85tercel
My tercel:: 85 Tercel fwd 5 door
Fenders
Post by Als85tercel »
Do sedan front fenders fit on wagons? They look like they should.
I bought a fwd wagon that's in much nicer shape than my sedan other than its bashed in passenger fender.
Mark
Re: Fenders
Post by Mark »
Do you mean hatchbacks? My '84 4wd wagon has fenders from an '83 hatchback and they were identical.
Re: Fenders
Good Morning Als85Tercel,
Based on your avatar pic, it appears you have a 4-door hatchback. I haven't seen many of those, most hatchbacks are 2 door. I believe the fenders will likely swap fine, though the corner lights and headlight surrounds may be a little different. I know there are differences between the 2WD and 4WD corner lights on the wagons.
Als85tercel
Re: Fenders
Thanks. I took them off of the hatch they appear to be the same. Ill clean them up and switch them over. I'll post an update when I'm done
Re: Fenders
Yes! all of the fenders are the same. some trim and external details, like the marker lights, are different. but fenders, and the hoods too, are interchangeable. some have the radio antenna on different sides, so you may have to plug an antenna mount hole.
