Possible missing choke-throttle part?
AlexArrow
My tercel:: 1986 Toyota Tercel SR5 Wagon 4WD
Post by AlexArrow »
After disassembling and reassembling the carburetor in order to clean all the gunk out, it would seem I lost a part in the process. Tried looking around, but nothing. I've circled the area in the photo. This is the point in which the choke(of which connects to it via a rod from the green bushing, below the circle) to the throttle lever/cam.
If I see how this piece looks, maybe it will help me find it, or at least fabricate a replacement. Can't find any pictures with a clear view of it.
ALiveSR5
My tercel:: Was a stock 1985, SR5, 4WD, 6-speed manual, Wagon.
Re: Possible missing choke-throttle part?
Post by ALiveSR5 »
AlexArrow wrote: Tue Nov 10, 2020 6:30 pm Can't find any pictures with a clear view of it.
I posted a video of a 3A-C carb on your Facebook post for this (I do not know how to post videos, here, or if it is possible).
For me, at least, it would be helpful to have a picture just a little further back, so there is some reference for the closer view that you provided - it would give me better perspective of the image.
Maybe you can see the part in the video.
No other vehicle that I have ever owned had a heart and soul like my 1985 Tercel SR5 4WD Wagon. :D
Great minds may think alike but it is the doers who see their visions become reality. :?
AlexArrow
Post by AlexArrow »
Okay
If needed, I can try to get another photo with everything installed.
AlexArrow
Post by AlexArrow »
I figured it out. It is all okay. The parts were just not yet touching, but seen it in operation today. That and the continued problems are likely more gunk.
it usually helps a lot of spray the choke, all the linkage and down the barrels with carb cleaner while it is running. lots of it, cleans out the gunk. it will prvent sticking of the moving parts.
I also like to spray a light lubricant on the external linkage, cables, etc. on all sides of the carb.
AlexArrow
Post by AlexArrow »
Figured out the problem. The old gas even clogged up the caps - both of them! Cleaned one out and no more vacuum in the tank. Runs so much better now!
ALiveSR5
Post by ALiveSR5 »
AlexArrow wrote: Fri Nov 13, 2020 3:43 pm Figured out the problem. Runs so much better now!
Good news! It is nice to learn how problems are resolved. :D
