Transmission Rebuild Kit
SirFoxx
Post by SirFoxx » Mon Jan 20, 2020 8:54 pm
Anyone order from here? It doesnt directly say if they still have the different rebuild kits in stock (z40 4spd, z50 5spd, z50f 5+1spd). If they do, sweet! Pricey, but worth it, especially if they have the syncros.
https://www.drivetrain.com/parts-catalo ... erhaul-kit
1988 DLX Tercel Wagon w/ weber (RIP)
1985 4wd Tercel SR5 (RIP)
1981 Toyota Tercel
teranfirbt
Re: Transmission Rebuild Kit
Post by teranfirbt » Tue Jan 21, 2020 9:39 am
I've called a few different places and haven't had any luck on those BK224 kits, no one actually had any stock. Always worth another try tho :-). Most of the cost comes from the crazy number of bearings that are in the Z50, it's easily twice as many as most typical FWD transverse transaxles. It would be nice to get front diff gears as well, that's the only part I've ever actually broken.
SirFoxx
Post by SirFoxx » Tue Jan 21, 2020 12:09 pm
Welp got a reply. And not a good one...
UNFORTUNATELY THESE KITS ARE NO LONGER AVAILABLE.
AS SOON AS THE LAST OF THE REMAINING INVENTORY WAS SOLD THAT WAS THE END AS NO ONE WOULD MAKE THEM FOR US ANYMORE.
THANKS
Why even list the products on the website and give a smidge of hope by saying "call for availability" instead of saying "out of stock"? Ugh...
1981 Toyota Tercel
Post by xirdneh » Tue Jan 21, 2020 11:39 pm
your best bet for finding synchros is to stop at every tranny shop you run across
have them look them up
they may find some dusty ones sitting on a shelf at their suppliers
i have found some doing that and some were pretty dusty
just get the two big ones
two required for 1st and 2nd gear (largest one)
two required for 3st and 4nd gear (second largest one)
i have quite a few good used ones for 5th gear and granny gear (3rd largest) that i can give away but they rarely wear out
Post by xirdneh » Tue Jan 21, 2020 11:42 pm
only three bearings ever go bad and all three are on front of tranny
there are 4 total on front of tranny and only the 3 largest ones ever go bad
they are all available
SirFoxx
Post by SirFoxx » Wed Jan 22, 2020 1:05 am
Which bearing(s) would cause excessive whining? I know these transmissions all whine, but the 4spd in my tercel whines like a freaking supercharger, and I'm really concerned that a bearing is about to blow out. Only happens when the car is moving, and is rpm dependent. It's not the throw out bearing, or the input shaft as it doesnt whine when the car is idling with my foot off the clutch.
You can hear it most notable around 0:12 and 0:27 in this video
https://www.youtube.com/watch?v=SP23I-0pM9A.
1981 Toyota Tercel
Post by xirdneh » Wed Jan 22, 2020 3:37 pm
whining is usually caused by the teeth on the gears.
if tranny was ever ran with low oil the teeth get messed up
the inner input bearing can be tested by pushing clutch pedal down while engine is idling
if there is noise at idle and it stop or drops in volume when pedal is down. thats the inner input bearing
i have never driven a tercel with bad front bearing but people who have tell be its more of a grind sound
Post by Petros » Wed Jan 22, 2020 8:14 pm
a small amount of bearing/gear whine is fairly common with manual gear boxes. if the lubrication is kept up to date, a whine can run for hundreds of thousands of miles and never cause any issues. it is the nature of gears that mesh together, the specific geometry is not obvious, but there is a sliding component there when one gear tooth face slips across the other, often causing a high speed harmonic that makes the whining noise.
As bob pointed out, the more worn or rough that surface, the louder that whining noise. the gear face itself is always riding on a layer of lubricant, that is why clean and proper lubricant is so important to the life of the gear box. metal partials in the lubricant will erode away those surfaces, making the whine louder. And there should never be metal on metal contact between the parts, if it does, as when it is run without/low gear oil, it will gall metal off the surfaces of each part in contact with another part fairly quickly. trashing the whole gear box.
SirFoxx
Post by SirFoxx » Wed Jan 22, 2020 9:51 pm
Sooo basically, either first or second gear is worn from what youre saying? Lol. Car only has 124k on it, though I am the 4th owner of it. Who knows how the previous owners treated the car. I recently changed the gear oil with basic 80w90 crap from walmart, but, when I get the 7age all ready to go, I'm going to put redline mt90 in it (or whatever the company recommends for yellow metal. I think its mt90...).
1981 Toyota Tercel
Post by xirdneh » Thu Jan 23, 2020 12:05 am
i have always used the GL-5 80-90or 85-90 inexpensive gear oil by the gallon that you get at oreillys and other car parts places
we have had several tercels since 1988 in the 280-350,000 mileage range and one that went to 445,000. the only tranny that ever gave us trouble was when 5th gear got messed up from pulling a too heavy trailer too many times. i know now not to use 5th gear when trailering
at 445,000 i took that tranny apart. the synchros still had life so i just brazed some brass on the worn steel shift forks
and stuck it back in the car. that was 6 years ago.
from what i have read GL-4 may save synchros but its not so great on differential gears
if GL-5 is supposed to be bad for synchros then i would expect all synchros in a high mileage tercel tranny to be close to equal wear
but what i see is one gears synchro worn down to Zero gap and the others are ok. so i believe thats because of the driver being harder on one particular gear for whatever reason.
my 1983 factory service manual says to use GL-5
The Professor
Post by The Professor » Mon Jan 27, 2020 8:56 am
When I first got my Tercel I drained the trans and refilled it with generic 80w-90 for only 2-3,000 miles (because 3rd gear started grinding after the fluid change). When I drained the generic fluid to swap to the Redline MT-90 the old fluid was FULL of brass flakes. Besides, at ~67 hp, these cars aren't really taxing the differential gears.
1975 Subaru SuperStar wagon
1984 Subaru Turbo-Traction wagon & Turbo-Traction hardtop
1987 Subaru RX 3-door, x2
1987 Subaru RX Type-RA 3-door
1987 Toyota Tercel SR5 wagon
1999 Subaru Forester S
2002 Subaru WRX sedan
Post by xirdneh » Mon Jan 27, 2020 2:23 pm
there is the possibility the oil had nothing to do with the flakes. not much different than when i tried GL-4 in a tercel and a month later the differential teeth broke off. the oil may not have been to blame in that case either.
