Oil filter and exhaust gasket 86/87 with CAT
solarlord
My tercel:: 1987 4wd Swiss model
Post by solarlord »
Happy new year folks- whenever i send off for a oil filter i get something that is much too small ,can anyone point me in the right direction ie filter make ,number - Also the joint between the cat and the end pipe is blowing does anybody know the gasket size for this exhaust joint ,Thanks Derek
Re: Oil filter and exhaust gasket 86/87 with CAT
Post by splatterdog »
I use a Motorcraft FL1A oil filter on mine. Ups the oil capacity a fair amount.
Check the part stores or dealer for the exhaust gasket. If there is an old muffler shop near you they might have it.
Abletobecain
Post by Abletobecain »
The Fram PH2951 is larger...and really cheap on RA.
2007 Tundra Limited Crewmax 4x4 ("Tetsuo Shima"/Hauler) SOLD :cry:
1987 DLX Tercel Wagon 4WD ("Lil Red") SOLD :)
Gaskets i have used for Aft end of CAT FEL-PRO 23561(smaller OD) or ROL EG24584 or FP-23591 or Walker 31332 (Large) ( 1.96 ID x 2.546 OD )
solarlord
Post by solarlord »
Nice to hear from you ,the filter i have on for years is the motorcraft ,was given it by a guy at the scrap yard in Mora la Nova ,it was for a Ford but its worked, ok nowi will get a Fram and another Motorcraft ,they cheap in the UK but are $20 in Spain - Xirdneh is the measurement in inches or mm thanks DEREK
that would be some pretty small gaskets if MM
for sure Inches
solarlord
Post by solarlord »
Xirdneh - thanks for that -DEREK
