My car is a 1987 Toyota Tercel DX Wagon RHD 1452cc 2bl manual driven car.
There is a clicking sound comes out from the Head Lights relay in the main fuse box.
Head lights are working properly
It is a continuous "tik" "tik" clicking sound. It seems relay contacts and detaches continuously.
Engine start is also poor.
I replaced it with a spare relay. It also emits that noise.
It seems that there is a wiring problem at that relay.
What type of wiring problem could cause such a thing?
Sound comes out from a electric relay
- Dumindu
- My tercel:: 1987 Toyota tercle 4wd DX Wagon 1452CC
- My tercel:: 1983 2wd tercel hatch back ,1986 SR5
Re: Sound comes out from a electric relay
I would first identify which relay it is. Then I would check the fuse or fuses that supply it with power. Then I would also check what switches or sensors that activate this problem some relay.
- Abletobecain
Is your battery fully charged with clean contacts and good clean grounds?
- Dumindu
You are correct.
It was the battery that caused the problem. I couldnt off the switch fully. So the clock was working for around 30 hours. It has eaten the battery charge.
After battery was fully charged, now problem was resolved.
- Abletobecain
Glad to hear its better, but will it happen again? Is there a problem with your ignition switch that will not allow it to turn off fully, or you just forgot to do so? I forget my lights turned on a lot. I want to add a buzzer or something.
- Dumindu
Ignition switch is usually turned off when remove the key.
But in order to off the interior lights and radio I need to press a button to turn the key an extra slot (last slot) in the ignition switch. ( In other cars I havent seen a such, perhaps only in the 1987 Tercel wagon)
I usually forget to do that.
- Abletobecain
That button is on all of the T4WDs as far as I know...it's on all of mine anyway. I forget it sometimes too.
that used to be a common item on japanese cars, I think my old '71 Datsun had one. I completely forget about it because it is just reflex to push on it as I turn the key.
