Inner Tie Rod Length
stefando
My tercel:: The Caribou: 1983 SR5
Post by stefando » Fri Aug 30, 2019 10:59 pm
Hey all,
Novice question maybe but I'm away from my car and book and wanted to order some parts asap so I'm turning to you all to try and get an answer about the inner tie rods for my 83. Manual steering, outer rods are shot and inners are going to get replaced at the same time so I went to order parts and rockauto has two lengths, neither of which describe that they are for something specific. 6.3 inches and 5.7 inches. I can measure on my car next week but I was hoping someone knows why there are two lengths, all the other variable components listed explain what they are for (power steering v. manual etc..) Is one for each side? i remember my cv axles were diff lengths because the diff is off center, is it the same sorta deal?
Thanks for the help!
_S
1983 SR5 Brown
Salmon River California
stefando
Re: Inner Tie Rod Length
Post by stefando » Sat Aug 31, 2019 11:23 am
Nobody knows?
1983 SR5 Brown
teranfirbt
Post by teranfirbt » Sat Aug 31, 2019 2:29 pm
Interesting, I imagine it's a 2WD vs. 4WD as toyodiy lists the same PN for manual or power racks...
In any case, if I were in your shoes I would buy the longer ones and cut them down if they need to be shorter, it's only an inch difference.
jimcrazy
Post by jimcrazy » Sat Aug 31, 2019 5:56 pm
i did not get a chance to check but if i remember right the manual rack takes the longer inner tie-rods,
Post by Petros » Sun Sep 01, 2019 12:32 am
FWD and 4wd front drive train, as well as the steering system, are identical.
the difference as I recall is the power steering uses slightly shorter tie roads because the power steering rack is about an inch larger. I have only seen manual steering for '83-84 model years, it may have been offered but all dealers got the power steering equipped cars only after '84.
stefando
Post by stefando » Sun Sep 01, 2019 1:43 pm
Thanks All, This saves me a bunch of days time. I'll order them now and they'll be waiting for me when I get home. Excited to get those shot outers taken care of. BTW: Moog outers lasted about 3 years and 30K and they are totally shot. I drive a ton of dirt roads but I was still surprised to see how wobbly they'd gotten. Cheers everyone.
1983 SR5 Brown
Ismo
My tercel:: 87 wagon
Post by Ismo » Tue Feb 18, 2020 10:02 pm
Sorry guy's I'm new.. so if I got the part number mes2377 and mev168 on rock auto for my wagon 87 3ac 4wd it's good? Just to be sure..
Post by Petros » Wed Feb 19, 2020 5:52 pm
post a link to the page with the parts you are asking about to make it easy for us to look at them.
you can compare them up close together to verify before you pull it apart. and than once you get it out, study them side by side.
