Harmonic Balancer
grouchytom
My tercel:: 87 SR5 Wagon
Harmonic Balancer
Post by grouchytom » Mon Aug 26, 2019 8:38 pm
When crank is on the crank timing mark the timing mark for the timing cover is approximately at 8oclock as viewed from the front of the motor. Could I have a bad balancer?
Re: Harmonic Balancer
Post by xirdneh » Tue Aug 27, 2019 12:28 am
The pulley could have separated. Its held in place with rubber by, probably what is called vulcanized.
Post by NWMO » Tue Aug 27, 2019 3:44 am
Tom,
What “crank” timing mark are you using besides the harmonic balancer?
Post by xirdneh » Tue Aug 27, 2019 7:36 am
I was thinking he might have the top belt cover off and was looking at lower crank belt pulley mark.
Post by Petros » Tue Aug 27, 2019 2:00 pm
the only way to know for sure is to take out the number one spark plug and visually get the piston to TDC using a flash light to look into the spark plug hole. You can see when the piston is exactly at TDC. than check the mark on the front blancer compared to the timing indicator. it should be at "O" when the piston is at the top of its travel.
if it is anywhere other than zero, the blanacer has to come off for inspection. several issues can cause this, a damaged or shear off key in the front pulley key-way, or a de-laminated harmonic balancer.
grouchytom
Post by grouchytom » Tue Aug 27, 2019 2:50 pm
believe its a de-lamintated harmonic balancer. Have timing cover off and belt disconected using the crank mark and mark on the block. puts it at #1 TDC Timing mark on balancer is at about 8o'clock instead of 1o'clock which would be 0.
grouchytom
Post by grouchytom » Tue Aug 27, 2019 2:52 pm
keyway is good on crank and balancer
Post by Petros » Tue Aug 27, 2019 10:09 pm
sounds like you need a new front pulley/balancer. That happens sometimes, oil weakens the bond as it ages, eventually it gives up.
there are places that can rebuild the old one, but finding a good used one is likely less expensive.
