Coolant leak?
Defend_Dingo
My tercel:: 86 4wd
Coolant leak?
Post by Defend_Dingo »
My engine bay smells like coolant and the coolant has been mysteriously disappearing but I cannot find a coolant leak anywhere
The overflow bottle also has a layer of what looks like grease on the inside but the coolant itself is completely clean
I have drained and refilled it several times already and the coolant was never dirty
Re: Coolant leak?
JD,
I would be doing a visual inspection when at operating temp. It may be that the leak is slow enough and in a spot that doesn't get to the ground easily, allowing any leaked coolant to be evaporated before showing itself. Thus the odor, the loss, but no puddling. Here are a few spots I would check first:
- steel bypass tube near thermostat, found a pin hole in mine
- radiator fins may show staining of a leak in the radiator itself
- base of thermostat housing
- hose ends
On a more fatalistic note, if none of the above seems to be the problem, I would pull the plugs and look for any "washing" on the plug ends and piston tops. I would also be looking for white smoke from the exhaust, particularly at start up. I would also pull the dipstick and look for any emulsion (white, milky streaking or coloration in the oil).
Defend_Dingo
My tercel:: 86 4wd
Re: Coolant leak?
NWMO wrote: Mon Jun 24, 2019 6:56 am JD,
- hose ends
There’s a little bit under the stem of that bypass thing, if it has a hole in it how do I get a new one? Or do I just figure it out
Are there gaskets on it, how hard is it to remove and replace and find new gaskets
Re: Coolant leak?
JD,
Mine had a hole in it and I sleeved it with a thin wall piece of brass, no problems to date. However, it appears the parts are still available and not ridiculous. I would pull it if I were you and check it out, it may be as simple as leaking past one of the o-rings. Here is a good link and it includes some additional links in Tom's responding post.
viewtopic.php?f=4&t=14002&p=105345&hilit=bypass#p105345
The Professor
Re: Coolant leak?
Post by The Professor »
JDNightFox wrote: Mon Jun 24, 2019 9:18 amThere’s a little bit under the stem of that bypass thing, if it has a hole in it how do I get a new one? Or do I just figure it out
I just bought the pipe, the O-rings and the housing gasket from the dealer. I think it was around $40 for all four parts.
1975 Subaru SuperStar wagon
1987 Subaru RX 3-door
1987 Subaru RX Type-RA 3-door
1987 Toyota Tercel SR5 wagon
1999 Subaru Forester S
2002 Subaru WRX sedan
Re: Coolant leak?
typically you may have a tine pin hole leak that only sprays steam when it is warm and running, once cool it leaves no sign of a leak. those are had to find, you have to inspect the engine while it is warm and running and watch for a source of steam spray (hard to see in day light, using a flash light at night is helpful, easy to see the mist).
if it is the by pass tube, that is an easy fix. replace, or have the tube welded is best, otherwise a patch with lots of RTV might work (consider it is under pressure). gaskets, o-rings, and the tube is still available.
Re: Coolant leak?
Post by irowiki »
Also the o-rings on each end of that tend to leak too.
Edit: how odd, the thread only showed the first reply until I replied :?
MrWrench
Re: Coolant leak?
Post by MrWrench »
Could always wait until it cools down and use a rental pressure tester from the parts store.
I could smell coolant after my engine rebuild a few weeks ago. I was a little nervous because I couldn't find anything and it was not dropping very quickly from the overflow tank.
The one I rented from AutoZone had a cap that fit our Tercels radiator cap perfect.
Pumped it up to 13psi and found my small leak. It was weeping around the house to the heater core. Tightened the clamp up and all has been well since.
Just another option for ya.
1983 AV-II Sprinter Carib.
Defend_Dingo
My tercel:: 86 4wd
Re: Coolant leak?
MrWrench wrote: Fri Jun 28, 2019 6:21 am Could always wait until it cools down and use a rental pressure tester from the parts store.
That's not a bad idea. I know there's residue around that bypass tube so that's at least one spot. The heater core was another spot but I tightened that hose, it may still be leaking so I might need to replace it
Re: Coolant leak?
Post by irowiki »
If the heater core is leaking you'll know it!
