Dieseling + backfiring + rough/searching idle
SinusoidalTendencies
My tercel:: 87 4wd wagon
Re: Dieseling + backfiring + rough/searching idle
Post by SinusoidalTendencies » Tue Apr 02, 2019 11:53 am
How about 1990 corolla? That's as old as it gets at Moss landing and Salinas yards. And a wee drive ta boot
Post by Petros » Tue Apr 02, 2019 7:39 pm
only if it has a 4ac engine. I think that year corolla should have a transverse engine with the distributor off the end of the cam shaft, so if I am remembering correctly, I do not think so.
Post by SinusoidalTendencies » Tue Apr 02, 2019 8:05 pm
If only there really was a distributor tear down with specs for the bearings.. since the fsm doesn't cover pressing them out or anything. Would love to just tear it apart but she'll probably get towed while I'm searching for the bearings or even a whole nother iia
Post by Petros » Wed Apr 03, 2019 10:58 pm
I have an extra distributor assembly I can send you. I have no idea if it is any good or nor, I grabbed it from a picknpull on a 50 percent off day as I recall. but the bearings are good on it. you can swap over your good parts.
PM me your shipping address and I will check the cost of mailing and give you a price.
Post by SinusoidalTendencies » Wed Apr 17, 2019 1:37 pm
apologies for the delayed update. had to go work a festival.
she still runs (if a bit shaky at idle and no more purring at 80) , and i am now in San Luis Obispo, CA instead of Santa Cruz
while the dizzy is still the #! suspect for a progressive issue with my timing and power output, i'm still suspecting other contributing factors
sent you a pm petros
