Factors affect for parking brake ?
Dumindu
Post by Dumindu » Fri Mar 08, 2019 7:09 pm
In my car Parking brake is not working. It can stop the car in a slight slope but not in a large slope.
Parking brake cable has a high tension on the lever attached to the shoe even without hand brake application (by the handle). I feel lever is pulled enough to have the brake even without brake application.
I found 3 factors that could possibly affect
  • Hand brake cables that goes to separate wheels are having uneven lengths. Right one is one inch longer than the left. So the equalizer is little bit rotated.
  • Cable covers present only at retainers. In between bare cables are seen. in some places cable covers are moving on the retainers when the hand brake is applied.
  • Auto adjustment mechanism on right side rear drum brake is not functioning. Auto adjustment lever is away from the star wheel. Reason I found is that there is a excessive play between levers. I am planning to replace the shim and C clips with adding a washer in-between.
What could be the mostly affecting factor for the poor hand brake that need to correct immediately?
Re: Factors affect for parking brake ?
Post by Petros » Sun Mar 10, 2019 3:39 pm
make sure your rear brake shoes are worn approx evenly, that could cause the different length of cable. Or just install new rear shoes if necessary.
also, adjust the rear brakes to the same amount of clearance. The shoes should just barely touch the drum when you have the adjustment correct, when you rotate the wheel you will hear the shoes just touching the drums. The auto adjusters will not make up for out of adjusted brakes, you have to manually adjust them first. the auto adjusters just compensate as teh shoes wear. you can get by without them working, it just means you have to get to the slot in the brake backing plate with a screw driver every few thousand miles (like we always used to do). but if you can get the parts installed correctly and in the right place, the adjuster should work normally.
Unless one cable was replaced with a different length one, it should not be uneven at the center linkage. the handle height adjustment is under the brake center console down low against the tunnel, adjusted from inside the car with the hand brake cover removed.
Dumindu
Post by Dumindu » Sun Mar 10, 2019 6:57 pm
Thanks.
Rear brake linings are nearly 4 mm in both sides. It is the best size as noted in FSM.
Yesterday I removed the Hand brake handle side nut and loosen the cable tension. Then adjusted the brake. This time I could see the Auto adjustment lever is in contact of the star wheel. Great tension in the cable was the factor that lead the levers to twist.
I found the cause of the problem when I tried to put the nut again. Cable is around one inch below in the tunnel. That means initial cable is short.
It seems that the previous owner has replaced cables those not appropriate to the vehicle. I am planning to get make cables by a cable maker (cables for Tercel not found in the local market). But I have to find the correct specs of the lengths of the cables. Now I am searching to find them. I found in ebay that two long cables should be 56.75" each. Since the initial short cable is a STD part now, its difficult to find the length.
jimcrazy
Post by jimcrazy » Mon Mar 11, 2019 3:25 am
the right is 56 3/4 and the left is 57 9/16
Dumindu
Post by Dumindu » Mon Mar 11, 2019 12:08 pm
Means left one is longer than the right one?
jimcrazy
Post by jimcrazy » Mon Mar 11, 2019 2:35 pm
yes,,i ordered a set from rockauto just to have on the shelf if i ever need them and the left is longer than the right,,https://www.rockauto.com/en/catalog/toy ... cable,1696
jimcrazy
Post by jimcrazy » Mon Mar 11, 2019 2:38 pm
if you click on the info tab of the raybestos bc93363 and bc93849 it gives you the length
