Is it need to have rubber washers at the line- master pump connection
Dumindu
Post by Dumindu » Wed Feb 27, 2019 8:09 pm
I did installed a new brake master pump.
When I disassemble the old one I didnt find any rubber washer at the connection of lines to the master pump.
When I install the new one, I did the same. I didnt put any washer.
Would it ok?
Can metal to metal connections prevent any leak?
Re: Is it need to have rubber washers at the line- master pump connection
Post by Petros » Wed Feb 27, 2019 11:41 pm
there are no washers or gaskets at the brake line connections. the conical shape of the flare hose nut makes all the seal it needs.
you are good to go.
Dumindu
Post by Dumindu » Thu Feb 28, 2019 6:47 am
Thank you very much.
Mr.Petros, You are doing a great service.
