Correct length Tie Rods and info
Re: Correct length Tie Rods and info
Post by ARCHINSTL » Thu Nov 29, 2018 8:58 pm
Well - back in 2006, I got both inner and outer tie rods from AutoZone for PS for $106.
Unfortunately, I did not file the part numbers, but I note that AZ does separate them for PS and MT - no dimensions shown, however.
https://www.autozone.com/suspension-ste ... ie-rod-end
Also check out my photos here:
viewtopic.php?f=2&t=3171&p=24331&hilit= ... ion#p24331
Post by ARCHINSTL » Mon Dec 03, 2018 2:16 am
Yup on "going strong;" still straight at speed on a Interstate!
Granted, they've not seen ANY use on unpaved tracks, but ...
Post by Petros » Mon Dec 03, 2018 9:32 pm
I always just get the lowest price items from rockauto for parts that I can verify are not Chinese made. Usually made in japan or USA are good quality parts. Price on RA is unrelated to quality. they get close out parts from various sources, some overseas, most domestic. One time I ordered brake parts for our Mazada, it was "private label" made in Japan, they were cheap. they came in NAPA boxes, NAPA supposedly only uses the same supplier as the factory and puts a lifetime warranty on them, but I got them for about 25% of the NAPA price. likley they were surplus parts they were unloading. No issues with quality.
The tie rod ends usually last a long time and really are not heavy wear items like disk rotors or a clutch. Just get the cheapest ones and get your car on the road, they will hold up fine. They are not that much work to replace again later if you have trouble, but for less than $20 whe really cares. You need your car running, just do it.
Post by ARCHINSTL » Tue Dec 04, 2018 4:21 pm
Yup on "Duralast."
Of course, that was 12 years ago, so who knows the manufacturer then - or now?
Post by Petros » Tue Dec 04, 2018 6:12 pm
Abra-Cadaver wrote:
Tue Dec 04, 2018 3:10 pm
How did you verify parts from RA are USA/JPN?
Usually in the detailed description on their website, when you click on the "more info" link, it will say country of origin. sometimes they list the manufacturer, and with the part number you can track it down from there.
stefando
My tercel:: The Caribou: 1983 SR5
Post by stefando » Fri Aug 30, 2019 3:42 pm
What's up with the 2 lengths of inner tie rods? I can't find it mentioned and this thread is the only place that seems to be appropriate to ask. Rockauto has inner tie rods for my 83 that come in 5.7 inches and 6.3 inches. They don't indicate whether one is for a manual or anything like that..
1983 SR5 Brown
Salmon River California
