Odd PS "Leak/absorption" ?
Goldie has never weeped/absorbed more than a drop or two in the 13 years she's owned me.
My Dexron ATF quart has grown cobwebs. Until now (well, sorta "now").
A couple of months ago I noticed a "squeal" that disappeared after a mile or so, but the PS worked normally. Upon getting home, I checked various and finally the PS reservoir, which was quite low.
Uh-Oh ...
Filled it (only took "a bit"), and I checked the pump, rack, and boots, and all were dry, and even placed a piece of cardboard under it overnight, then ran the engine and turned the wheel back and forth - no drops and no squeal. :?:
I am guessing perhaps 700-1,000 miles later ...
Flash to yesterday - the same thing happened and I followed the same procedure as before. Squeal stopped when fluid added, but I did not investigate further (snow falling and too darn cold).
Ideas? I don't think anyone has reported similar before.
Thanks,
rer233
My tercel:: Multiple
Re: Odd PS "Leak/absorption" ?
Post by rer233 »
Tom-
Check the steel P/S pressure and return lines that run under the radiator ( you'll probably have to remove the gravel tray to access.) I've had 3 wagons develop rusty pin-hole leaks (never did determine whether it was press. or return-just replaced both.) R/A sells the pressure hose, and I made the return from 5/16" (I think) copper tubing I got from a refrigeration supply house. Bit of a PIA, but doable.
Good luck, Rich.
Jarf
My tercel:: Currently without
Post by Jarf »
Tom - the other place that PS fluid can disappear to, is inside the rack boots, when the rack end seals fail, fluid will leak into the boot, if the boot seal is good they can fill up like a balloon.
Each boot can hold upwards of a cup of fluid.
Thanks, guys. Will check when snow disappears (no garage).
Since the boots are dry, I had not thought about them retaining fluid. If I had to guess on the amount of fluid I replaced in the two occasions, I'd say maybe a couple of ounces at best.
Tom M..
