Cam Lobe position when ignition happens
Dumindu
Post by Dumindu »
My car engine is having a problem.
When valve timing is adjusted, What is the position of the Intake Cam Lobe that contact with the rocker arm when ignition happens?
Re: Cam Lobe position when ignition happens
For number one cylinder both lobes are down. Timing mark on crankpulley at zero. Timing hole on cambelt gear lined up with arrow.
https://www.youtube.com/watch?v=fS3bAwwR43w
Dumindu
Post by Dumindu »
I havent disassembled the cam. So I dont know about the cam shaft and cam timing pulley structure. When cam pulley is disassembled from camshaft, and re-assembled, should we fix it to a precise angle or is there any mark, cut or any groove (As in crankshaft - crank pulley connection) to auto fix the angle?
the cam and gears on both ends can only be assembled one way because there are alignment pins
Dumindu
Post by Dumindu »
Thank you for the advice.
Dumindu
Post by Dumindu »
Finally I found that the both lobes on exhaust and the intake valve should pointed downwards. (around 45 degrees)
