Can you stiffen rear suspension with little to no lift?
marlinh
Post by marlinh »
I have been going through the various lift topics without success. I run 13" tires on my cars and have no interest in lifting the car but I would like to stiffen the rear suspension so I can carry heavier loads without the car sagging. Someone said the pathfinder springs don't necessarily raise the rear and some say they do. Can anyone clear this up for me? An inch or so lift would be OK. Thanks.
Re: Can you stiffen rear suspension with little to no lift?
install air adjustable shocks. You can adjust the ride height according to the load. you can get these great little 12v air compressors to mate to your air shocks from many Mercedes, Lincolns and MPV 4x4 vans, and several others, and just connect it to a manual switch so you can adjust the ride height as you desire from the driver's seat.
ride height has several variables, you can have a soft spring with a longer compression, or a short stiff spring, give the same ride height, yet have very different behavior and performance. A longer spring cut down will be stiffer, and also could give a lower ride height.
