My car engine gone bad and there was a white smoke emission.
Then I Fully repaired the engine including re-boring, piston, gasket, valve and valve-guide replacing and valve seat repairing. Engine was rebuild with re-installing water jackets and filling the external dents in the head. No externally visible cracks were found in the head and the block.
The white smoke is not controlled even after full engine repair.
Today serious accident happen.
I left the engine start for about 20 minutes to see what happens.
Engine temperature was very high. White smoke ex-aggregated. Finally with a huge sound Radiator exploded. Fortunately I was at my home for some work. No one was near.
Spilled water was green-brownish.
What could be the reason?
Could it be due to a clogged radiator caused a high water pressure in the engine which lead water to enter through gasket to the ignition chamber?
Or cracked engine caused the whole process?
Radiator explotion
- Dumindu
Radiator explotion
- slimdude85
- My tercel:: 1981 Toyota Tercel
Re: Radiator explotion
Sounds like exhaust gasses are entering the cooling system due to a blown head gasket or cracked head, causing extreme pressure to build up in the cooling system resulting in an exploding radiator. I was working one day when that happened in the oil change bay next to me. Quite the loud noise.
Proverbs 3:25-26
Proverbs 3:25-26
