Oil Pump Question
seantp
My tercel:: 1983 SR5 4WD Wagon
Oil Pump Question
Post by seantp »
Yesterday I noticed the oil light came on during a hard stop. Today it was flickering on more frequently. The dipstick showed the oil was down about a quart, if that. The last time my oil light came on, my dipstick was almost dry. Could the light coming on for the past couple of days be indicating that the oil pump going? I have 222k miles. Also, when I topped off the oil with a quart tonight, I added about four ounces of Sea Foam. The oil light has stopped coming on. So... do I need a new oil pump or...? Thanks for your help.
rer233
My tercel:: Multiple
Re: Oil Pump Question
Post by rer233 »
20 years ago I had a similar problem with a former GF's '84 FWD wagon- turned out it had a bad oil pressure switch. That engine's still running fine today ('course it only had about 120K on the clock then.)
seantp
Post by seantp »
It happened again. I wasn't breaking this time but shifting from 3rd to neutral on a downhill. The RPMs dropped down to about 500 then bounced back up and the light went off. Come to think of it there may have been a correlation between the light coming on and downhills all along.
i have had three senders go bad. its a cheap fix so i would try that first
marlinh
Post by marlinh »
Ditto. These oil pumps are very durable. It would be a good idea to try and locate the oil leaks and fix them also.
splatterdog
Post by splatterdog »
The senders on these rarely leak when bad. I've had at least a couple that did the same thing, and was always the sender. My theory is that the sender leaks internally which equalizes pressure on each side of the spring loaded switch inside. Cheap and easy fix..
Keep oil on the stick!
Unless you are flushing the crankcase, avoid seafoam in the oil, it thins it. Todays oils really don't need any help. If you oil loss is from the sticky oil control rings I have used Berryman B12 to help free them up as a last desperate act. When the oil is down some, add a full can to a cold engine. Start and idle until it's warmed up, then drain out the oil. A word of warning though, you might open up leaks by getting rid of goop that's currently blocking that leak. If it's really ugly inside, you can also clog the pickup screen with dislodged crud. Berryman makes seafoam seem like water as far as cutting carbon.
you may have work away your bearings by running with low oil enough to cause low oil pressue at idle. OTOH, could be the sender, or as happened on my daily driver, the wire chaffed and makes ground contact (making my oil like flicker on and off at random).
THIS IS IMPORTANT TO KNOW! install an after market oil pressure gauge, cheap at any autoparts store or from ebay, I like the mechanical one with the hydraulic line, but they are more troublesome to install. Than drive it so you really KNOW what the oil pressure is actually doing. if your oil pressure is low, and near zero at warm idle, it is time to replace the bearings and likely the oil pump. If your oil pressue is within factory specs, than it is likely the sender, or a bad wiring shorting out (I never did find my short, I just kept the oil pressure gauge in place, and even though the sender and light are disconneceted my oil light still flickers on sometimes!).
Though the oil pump is unusually durable and long lasting, but it does pump unfiltered oil. so if you or the previous owner tended just top it up, and to change the oil rarely (like I do), the oil pump will wear out internally. there are a few things to can do yourself to recondition the oil pump if not too badly worn out, but if there is any question it should be replaced.
It would be best to keep the oil idiot light and the gauge, that way you get a warning visible warning if you suddenly loose oil pressure.
It is critically important you verify if you have oil pressure. I had an old beater toyota truck with lots of miles on it (bought it for $600, but it was a good work horse), oil like would flicker on and off between shifts and at traffic stops. I installed the gauge and saw only 6-8 psi at idle, on hot days it almost nothing. I kept driving it, running pressie was 15-18 psi (low but still pumping oil to the bearings), I did not have time, I was in the middle of building our new house and had a full time job. Than one hot day the engine threw a rod. And I not only got to do a full rebuild anyway, I had lost a day getting my truck towned home. Before, I would have been facing a bearing and ring job, now I had to replace the whole engine. not one internal parts was salvageable, even the head took a beating as the piston was striking the head before it big end lets loose and drove itself though the side of the engine. it all became scrap metal.
So ALWAYS DIAGNOSE the PROBLEM BEFORE you try and FIX IT!
