Need Electrical Question Answered
Post by xirdneh » Sun Apr 01, 2018 1:00 pm
i am so frustrated
i have hooked up dozens of radios on these tercels
but this one is driving me insane
i hooked up the new radio in the car and it will not turn on
i hooked it up on the bench and it turns on
put it back in the car and it does not work
I checked the wires and the ALWAYS HOT (red) wire has 12v
the ACC (pink/blue) has 12v when key is turned to acc
the ground wire is good
but radio does not turn on
so i decided to do a test
i ran a wire direct from positive terminal and hooked it to ALWAYS HOT radio plug wire
that did not do anything
then i tried connecting it to the ACC radio plug wire and the radio turned on
so problem solved, even though i was getting 12v at the ACC (pink/Blue) wire with key turned to acc it does not work when connected to the radio
it makes no sense?
slimdude85
Re: Need Electrical Question Answered
Post by slimdude85 » Sun Apr 01, 2018 2:21 pm
The wire may have too much resistance, resulting in the current to the radio being reduced to the point of not being able to power on. You’ve got the voltage, but you may not have the amperage. Could be caused by corrosion, broken wire strands, terminals that are corroded, etc. Finding the cause is the fun part. If you have an auto ranging multi-meter, you’re halfway there.
‭‭Proverbs‬ ‭3:25-26
Post by Petros » Sun Apr 01, 2018 11:29 pm
sounds like a bad connection somewhere in the wire, might even be a weak contact in the ignition switch itself. I have taken the ignition switch out and took it apart, cleaned the contacts and bent them a little so they made better contact, and reassembled it so it would work again.
You might also check to see if there is an in line after market fuse in the power wire. if someone installed an aftermarket radio they pay have installed an in line fuse (usually a white plastic housing in-line with the wire a bit larger than glass tube w/wire fuse). check the connection in the fuse contacts.
Post by xirdneh » Mon Apr 02, 2018 4:19 pm
the cigarette lighter runs off ACC so i connected to it and radio worked
i will install a 7.5 fuse in between
