Rear axle input
JDNightFox
My tercel:: 1986 SR5 / 1987 SR5
Rear axle input
Post by JDNightFox » Wed Mar 21, 2018 6:07 pm
It looks like the propeller to input shaft seal is leaking really bad on my rear axle
from other research it looks like this is going to be a PITA, so would an easier option be to swap the rear axle completely with an LSD that has 3.83 gears from an ae86 (I need to change the gears out anyway because of the front and rear having different gearing
the bolt pattern isn’t a big issue because I can just buy rims that have both 4x100 and 4x114 together
Re: Rear axle input
Post by xirdneh » Wed Mar 21, 2018 7:02 pm
it would be easier to swap the differential only and that would be 3.73 (vs 3.8)
also there is a youtube video for replacing the seal
