Toyota tercel sr5 3 door transmission needs help
tommynguyen
My tercel:: sr5 1982
Post by tommynguyen » Wed Mar 14, 2018 7:47 pm
Dear everyone,
I come from Vietnam, I have an sr5 3 door 1982 and my transmission were broken some shafts. I can't find any gearbox for my car in Vietnam. The longitude 3A engine and FWD is really rare in VN for now.
My question is: the Aisin Z51 gearbox for my Tercel can find in any car model? Can I use the part from them to my gearbox? any replacement for my gearbox? Can I convert from FWD to RWD in case can't find part or gearbox?
Thank alot,
Tom
Re: Toyota tercel sr5 3 door transmission needs help
Post by Petros » Wed Mar 14, 2018 11:49 pm
welcome to the forum!
i think any fwd Tercel trans from about 1980 through 1986 can be made to work, 4 speed, 5 speed or automatic. the 4wd trans can likely be made to work too, but that would be a shame, better keep it in the 4wd Tercel and fix that one to make it into a daily driver.
The trans configuration in the early first and second generation tercels is unique and will not work in any other model, so you have to find any version of a tercel trans from those years.
tommynguyen
Post by tommynguyen » Thu Mar 15, 2018 1:25 am
So you mean I need to find the tercel' gearbox 80-86 then ok? Then I will to find. Tks alot.
Post by Petros » Thu Mar 15, 2018 4:07 pm
yes, there are 4 speed, and 5 speed front drive transmissions, automatics that all came with the first and second generation Tercel. All have slight differences in how they mount, but you should be able to adapt them with either minor mods or with the mounting hardware from the vehicle you got it out of, or by swapping over your mounting hardware in your car.
There is also of course the 4wd trans, if that is all you can find, it can be made to work in your car. It is almost the same but with the rear transfer case that goes to the rear axle. you likely can have a transmission shop swap out the rear housing and main shaft from your old trans, to replace the transfer case. You can also just leave the transfer case in place, but you need plug the rear drive shaft out put by getting the front end of the rear drive shaft, cut it off and just use it as a plug. This will keep the gear oil from leaking out the rear output opening.
good luck.
