New clutch - pull engine or transmission?
marlinh
Re: New clutch - pull engine or transmission?
Post by marlinh »
Did you get the flywheel machined? If the pressure plate was fried, the pressure plate probably had hot spots in it too.
spencercat
My tercel:: '84 SR5
Post by spencercat »
@marlinh - sorry for the late reply, but I've been working on my other rides. I didn't get the flywheel machined, it didn't look fried/warped/beat up. Scrubbed it with a scrubber pad, cleaned it with brake clean then acetone, and it looked fine.
spencercat
My tercel:: '84 SR5
Following up re the transmission fluid and whining. Gearshifts began to be a bit harder, and the whining was increasing. Today I checked the fluid level, found it flowing out of the full hole. But when I drained it, I only had 3.2 quarts in the tranny. :shock:
After taking an hour and a half to fill it up (with some lucas oil for good luck) to 4.1 quarts 80W90 it seems happier.
Lesson learned - don't trust the fact that gear oil runs out of the fill hole if there are other indicators that the level may be low.
I have found that a rest is needed while filling tranny.
I pump till oil overflows then wait about 20 minutes and pump again till it overflows. It takes about 5 cycles to get it full.
spencercat
My tercel:: '84 SR5
It did take about 2 hours to fill, with a quart-size graduated funnel and a long tube to the front most fill hole. I ended up getting frustrated that the last 1/4 quart wouldn't stay in, so I dropped the rear of the car off the jackstands and put the rest in. ;)
@abracadaver - I hear you about an oily belt and the PITA to get at it. It's on my list, believe me! Parts are here, it just needs to wait its turn.
Hari
My tercel:: 1984 Toyota tercel 4wd, lifted 14" tires
Post by Hari »
83s and 84s have more trouble pulling and installing he tranny. Clearance issue with the firewall. Better on the 85 and later. Buy a couple of bolts with the same thread as the main engine mounting bolts but at least 2 inches longer. When you are getting lined up screw them
Into the two bottom mounts on the engine. They help line things up as the engine/tranny mate up. I'd pull the engine on an 83 or 84.
that might be helpful, but the trouble is really getting it to line up at all.
you DO NOT btw, want to "pull" the engine to the trans by tightening those longer bolts. if something is not aligned you can cause severe damage to the trans. I have seen it happen where the trans case was badly damaged because someone could not get the engine and trans to mate because the spline was not aligned, he had used the bolts to suck up the gap to "force" it together. The main shaft pushed it way out the back of the transmission case (it was not on a Tercel).
Installing tranny with input shaft removed helps too
splatterdog
Post by splatterdog »
Petros wrote: Mon Jul 23, 2018 12:28 am that might be helpful, but the trouble is really getting it to line up at all.
It's not called a bell housing just over shape. A coworker once used the bolts to suck it up and the GONGGGG of the newly cracked housing was loud and clear over all other shop noises.
