gearing
Defend_Dingo
My tercel:: 86 4wd
gearing
Post by Defend_Dingo »
So as I currently stand, my car has 3.73 in front and 4.11 in back
I have the front hub assembly from the blown up transmission sitting on the floor in my garage. How hard is it to swap out the gears in the front axle? I don't have a rear assembly so I can't swap the rear axle gears
rocketscience
My tercel:: 1983 4WD SR5
Re: gearing
Post by rocketscience »
By front hub assembly do you mean the front differential housing?
You can separate the front diff/bellhousing part of the transmission and put it on the transmission in your car now as long as the gears weren't damaged when the transmission blew up, but you need to pull the transmission. I don't know how hard it would be to swap the gears into your current housing but you'd need to know how to set up the gear lash.
Defend_Dingo
My tercel:: 86 4wd
Re: gearing
rocketscience wrote: Wed Feb 28, 2018 10:58 am By front hub assembly do you mean the front differential housing?
Yeah I have the entire front hub assembly in one piece
Re: gearing
I would not trade out just the gears, requires setting the lash correctly or you will blow it too. but you can change out the whole front diff assembly as a unit.
you can separate the front bellhousing/diff assembly from the gear box, pull the front cover on the diff, and clean it out really good with solvent, compressed air, etc. Than carefully inspect the faces of the gears, and look for metal shavings. If your trans went all at once, the front assembly is likely okay to reuse because it likely did not spread the metal fragements to the front diff, but if the ring and pinion gears are damaged from metal fragments (scratched up, changing colors-bluish-yellowish, missing teeth or parts of teeth), better look for another diff. you could not use these even you just took out the gears.
So if the gears are good likely you can swap over the whole assembly (including the housing) without removing the gears and bearings, that would disturb their sensitive clearance setting (known as gear lash). Swapping out the front diff assbly/bellhousing is straight forward, simple job, just unbolt the old one and bolt on the new one.
rer233
My tercel:: Multiple
Re: gearing
Post by rer233 »
If I were you, I'd look for a 3.73 rear "pumpkin"- lots easier to swap out (unless of course you already have a clutch related problem that requires tranny removal.) Also 3.73's are more highway-friendly (10% less RPMs than 4.10's.) Meanwhile, I'd remove the rear section of the driveshaft so at least the EL function can be used (and prevent possible damage if someone inadvertently engages 4WD.) Just my 2 cents...
Re: gearing
each of the different final drive gear ratios have advanages, the 3.73:1 is more quite at highway speeds since the engine is running at a lower RPM. The 4.10:1 is better for steep terrain and rough roads, it is especially nice for starting out on a steep hill, on pavement or off road.
Both appear to get a bout the same fuel economy based on reports on this forum and my own experience owing both. With a mildly built 4ac with more power I have come to appreciate the lower rpm and less noise at fwy speeds, with the extra power not having as good a low end is not as much as a problem as it might be with a stock under-powered 3ac. OTOH, if you intend to build up a powerful engine such as a 4age, 4afe, or even a built up 4ac, the 4.10:1 final drive puts the max torque RPM range in a better location on the power band where it is useful. high output engines tend to develop their best power at higher rpms than stock engines, so the lower ratio is better suited to the higher rpm output.
Defend_Dingo
My tercel:: 86 4wd
Re: gearing
I like the lower gear ratio but I don't know where I would find a 3.73 rear end at, I just want to be able to use the 4wd again when I want to
I use this car for long distance road trips so the lower highway rpm is what I currently like, except that my top speed is 55 uphill
rer233
Re: gearing
Post by rer233 »
So downshift to 4th!
