84 Tercel SR5 19mm oil plug, what gasket to use?
mountaindude
My tercel:: 1984, 1985
Post by mountaindude »
19mm oil plug. Where to find correct gasket? Thanks.
Re: 84 Tercel SR5 19mm oil plug, what gasket to use?
most auto parts stores have generic soft gaskets for the oil drain plug of various sizes, they are cheap (like $0.19), if not sure get several sizes.
I usually make my own with gasket material and apply non-hardening gasket goo to both sides. I also goop up the plug threads. Never had a leak doing this. I have tried some store bought washers of different types but some have leaked. Draining oil to fix leak is irritating. If I had to use a washer the ones that are metal with rubber impregnated seal seem the best. I'm sticking with my method.
SynthDesign
Post by SynthDesign »
Buy it at Toyota when you buy the filter. The combo at retail should be less than $10. If you can't get one, send me a PM with your address and Ill toss it in the post. Don't use the crappy autodepot store ones. They always leak.
2005 Toyota Sienna, work van
85 Toyota MR2 (Blu)
83 Mazda RX-7 Mariah Widebody
splatterdog
Post by splatterdog »
If yours is having trouble sealing make sure to check the pan. The early big plug pans had a small square channel in the threads of the pan to allow a better drain. But, the pan sheet metal can get compressed in to this channel making drain plug sealing impossible. On two, I've welded a large washer to the pan, creating a new and much thicker sealing surface. Trying to do that in car is a PIA. Second one was done as PM while the pan was off, clean/dry, and upside down..
The dealer should have the 100% correct gasket.
