Front bumper
Ellisdee
My tercel:: 1985 wagon
Front bumper
Post by Ellisdee »
I just removed the front bumper on my Tercel to add some brackets for a tow bar...this forum described the two fourteen mm bolts on each side...wrong...there are four bolts per side...2 accessible from the front and 2 more accessible only after removing the grill and then a u-joint socket is needed...these two buggers are on the top of the frame rails and underneath the headlight buckets...there are various other 10mm bolts, but these are obvious...
