WTB: Outside handle for front passenger door
garyfish
Post by garyfish »
Well, it happened. A couple weeks ago the outside door handle on the front passenger's side of my '87 wagon broke, and now I can only open the door from the inside.
It doesn't seem like it can be repaired with any assurance that the repair will last. The inside of the plastic handle broke where the metal pivot was molded into the plastic. There are stress cracks all around where the pivot was, and I don't think that it can be permanently fixed with superglue or any other adhesive.
I've visited the one wrecking yard that's within 100 miles of here, and they don't have any suitable donor vehicles. (Note: In a post by Petros in June 2011, he noted that the "handle is common to all of the Tercels from '83 thourgh 86, and wagons through '88.")
https://tercel4wd.com/forums/viewtopic. ... 565#p49286
Compounding the problem, it appears that one or more of the plastic clips (that secure the rods attached to the pivot lever) broke when an overzealous passenger tried to force open the window and damaged the mechanism which was flopping around inside the door.
Any chance anybody out there has the part(s) I need?
rer233
My tercel:: Multiple
Re: WTB: Outside handle for front passenger door
Post by rer233 »
I'll have to check my stock this evening- should have one somewhere.
Post by splatterdog »
Another byproduct of that failure is also door opening when the window is rolled down..
Too late now, but some careful prying through the window opening will allow spraying lube down on the pivot point. The cracking is from swelling rust.
garyfish
Post by garyfish »
rer233 -- Thanks for checking!!
rer233
Post by rer233 »
PM sent.
garyfish
Post by garyfish »
Door handle found! ... big-time thanks to rer233
