My car is a Toyota Tercel 1987 4WD 1452CC DX Wagon. It has a Aisen 14120 2 BL Carburetor
Can I use a Metal Epoxy welder for repair a dent in the Cast Iron part of the carburetor?
Can it tolerate the heat?
Can I use a Metal Epoxy welder for carburetor ?
- Dumindu
Re: Can I use a Metal Epoxy welder for carburetor ?
I would do it. I usually use JBWELD
- helipilot77
- My tercel:: 1984 SR5 wagon
. / TOYOTA
./_| |/|/ |]
./_| |/|/ |]
- Dumindu
Thank you for your valuable sharing of knowledge and experience.
not sure I have ever seen a 4 barrel carb on a Tercel, but epoxy is a common repair for carbs. makes sure you clean it real good.
Carbs do not get that hot or the fuel would vaporize and cause vapor lock. Quality epoxy should work fine.
I have even seen epoxy used to seal up water leaks in a head, sometimes aluminum can have some porosity that causes coolant to seep into the intake, epoxy seals it up.
- Dumindu
Very sorry. It's 2 barrel. I have done a mistake while typing. I edited the question.
I figured, I was just teasing. if you really had a 4 barrel carb, I want to see a picture of it, and hunt one up for my tercel!
