Wiper blowing fuse
SirFoxx
Wiper blowing fuse
Post by SirFoxx »
Hello--
On my '85, I've got most of the issues sorted, except for one. When I got the car, the ash tray was full of 20A fuses. I found out those were only for the wiper circuit. Sometimes, when I put the fuse in, it'll last a day or so two before it blows again. Other times, when I touch the fuse to the contacts, I get a nice blue arc, indicating there is a dead short somewhere. I've already replaced the column switch, but that didn't fix it.
Where should I look? What areas could be trouble areas? Firewall?
1985 4wd Tercel SR5 (RIP)
Re: Wiper blowing fuse
you might try running a jumper wire, direct from the fuse to the wiper connector, disconnecting the factory wire. that is to eliminate the possibility that the wire bundle somewhere is abraded and causing a short. the motor itself can short out too, jumping it will tell you if it bad wiring, or the motor.
finding damages wires internal to the wire bundle is a troublesome, but first make sure it is not the motor itself.
splatterdog
Post by splatterdog »
Disconnect the wiper motor whenever possible to eliminate that. Keeps blowing and you need to find the rubbed thru wire. Scabbing in another wire can work in a pinch, but when a wire has problems the ones right next to it can too. Look for rub points on sharp dash metal.
I've been waiting for one of these problems to use my thermal imager on. You set up a self resetting circuit breaker to safely feed the circuit. This heats up the wire only up to the short to ground.
I should have clarified, splatterdog is correct of course. the point of using a jumper wire is as a diagnostic tool. If you use the jumper for a few days and the fuse does not blow, than you know it is a problem with the wiring, and not the motor.
If you use the jumper and still get blown fuses, chances are it is within the motor, or wiring within the motor.
Intermittent problems are always a hassle, using the jumper wire is a way of narrowing down so you are not wasting time looking for a short in the wrong place.
marlinh
Post by marlinh »
Have you checked to make sure the pivots for the wipers aren't seized? Just a thought, maybe that's why it's blowing fuses intermittently.
SirFoxx
Post by SirFoxx »
The problem isnt that it's blowing them while the wipers are on. The fuses are blowing when I'm driving. I'll put a fuse in, itll work (sometimes), then a few days later, when I need to clean my windshield, the fuse is blown again. I doubt its a short in a motor since both wiper motors work fine.
My guess is there's a short in the harness. The reason I say this is because mice had made this tercel their home for awhile, and decided to move out sometime before I got the car. The car reeked of piss, the headliner is sagging and has what appears to be piss stains, and my rear speakers don't work. I'm not sure where the harness runs for the speakers and rear wiper, but if they run along the same channel, it'd make sense why the speakers don't work, and the wiper fuse is blowing (shorting to frame / body). Now, it is possible that the rear speakers are shot, but I would like to believe that both issues are related.
rer233
My tercel:: Multiple
Post by rer233 »
If the fuse in question also controls the rear wiper, check where the wiring harness passes from the main car body to the rear hatch- I've seen wires break there, and it's possible the insulation could rub thru- causing your short. Also be aware that the "park" wire for the motor sees 12v whenever the ignition is switched on (regardless of whether the wiper is on or off.) My money's on that situation. Good Luck!
