Carburetor question.
- Togashi
- My tercel:: 1985 Tercel Wagon Basic
Does anyone know if the cam and carb on an auto 4wd are different than the 5 speed?
There is no such thing as a "little rust"
- Gottolovem
Re: Carburetor question.
Good question
The carb IS the same and I'm almost positive the cam is the same to.
i have found a few minor variations among tercel carbs. the differences have been in the # of vacuum ports and sizes of the jets. however, i'm not sure if these differences were due to auto/manual transmissions or year-to-year changes in emission controls. regardless, all tercel carbs cab be made to work if they are not quite the correct one.
not sure about the cam but i would wager money they're identical.
I seem to remember the auto trans cam had a different profile. It is not a lot different, so either one would work. the auto trans cars have a lower final drive ratio (since it only has a three speed trans) so the engine cruises at much higher rpms if I recall, which might be why the cam is different.
Interesting Peter, maybe I need to dig up the cam from Party's old engine and see if I can take measurements someday.
