Party Wagon head gasket thread
Re: Party Wagon head gasket thread
Post by irowiki » Tue Feb 24, 2015 7:07 am
Hey Peter, interesting info for us as I didn't know that was valve noise! Do you still hear the valve chatter when the engine is warm?
http://youtu.be/IZZ0PtHe4d8
(I actually hear something I didn't hear while listening to the car while taking the video, it is higher pitched like metal tapping, is that the valves?)
We were actually thinking of that, at the 500 mile mark when we re torqued the head gasket, to adjust the valves while we were in there so it was done.
81 Coachmen RV, 70k miles
95 Camry Wagon, 153k miles
04 Camry Sedan, 250k miles
Mark
Post by Mark » Tue Feb 24, 2015 6:26 pm
About a year ago I decided to check/adjust the valve clearances on my wagon just because I felt like I should. Since the engine was warm I used the "hot" specs from the manual (intake=.008mm, exhaust=.012mm). Afterwards, I heard that clatter when the engine was running (I didn't hear it before I adjusted the clearances). Today I figured I'd try it again. I used the hot specs and they were still good, but I adjusted the gap slightly smaller than spec to try and get rid of the clatter. I put the feeler gauge in the gap and screwed in the adjuster until there was a good "grab" on the feeler gauge. To properly do it, you're supposed to just feel "slight drag" on the feeler gauge. Anyway, there's still the clatter, but not as bad as before. Maybe my feeler gauges are cheap and defective. I'm afraid to adjust the valves too close and risk damaging them. I'll just live with a bit of clatter for now.
Post by Petros » Wed Feb 25, 2015 4:00 pm
usually if adjusted correctly you can hear the valves, not not notice any particularly loud one over the rest. it is particularly noticeable when one is out and clicking louder over the others. That is what I heard on the video clip.
I have never found using the cold settings worked, I always had noticeable valve chatter. But using the hot specs, with the engine as hot as I can stand to work on it (right after shut down), you get quite valves. but yes, be very careful you do have NOT too small a gap, particularly on the exhaust valves, if they get hot and do not seat, you will overheat the valve and it will break off inside the engine and do a lot of expensive damage.
Sometimes worn out valve stems will cause chatter even if adjusted properly, not much you can do about those. the valve noise does not harm a thing, it is just annoying. My old volvo 122s had a push rod engine with .022 valve clearance, it always had noisy valves because of it. You can hear the valves tapping away from across the street!
