Repair Manual For Standart Tercel Wagon 4WD 86'
J Dumarais
My tercel:: Toyota Tercel 4WD Wagon '86 & Jose 87' Tercel 4WD Wagon
Post by J Dumarais »
I gifted my self with a Tercel 4wd 86', Im living in Quebec and here those Cars are thing of the past. Imposible to find a Repair Manual. I saw a couple of PDF here but im not sure If i can use it for the 86'. I need expertise to comfirm that before starting my restauration.
Thank!
Re: Repair Manual For Standart Tercel Wagon 4WD 86'
83-88 there is not much difference mechanically so the manual will be ok
Welcome to the forum!
I beleive the manual off this site is from 1985, the only different between an '85 ad 86 is the seat fabric pattern on the SR5 model. Perhaps there were a few different connectors or or other minor detail differences in the wire bundle, but that does (and the seat fabric pattern) do not even show up in the maintenance manual.
That manual should serve you just fine, it will have everything you need to know relevant to your Tercel. And what is not covered in the manual, there is this forum, its archives, and hundreds of years worth of experiance with the Tercel among the other forum members willing to help you keep your Tercel on the road.
Congratulations on obtaining your first Tercel. This is an awesome site full of helpful people.
RCinNM
My tercel:: 1986 Toyota Tercel DLX 4x4 wagon
Post by RCinNM »
I just bought a 1986 Tercel wagon DLX 4x4 (5 sped w/EL) through an online auction. It was sold as inoperable, but after charging the battery and putting gas, it started right up. I’m looking for both side mirrors and a deck (?) for the back. I’m hoping to fix this up as my daily driver. In the past, I’ve owned a 1980 and 1982 Toyota Corolla Tercels cars, both 4 door, both with manual transmission.
Greetings RCinNM, there are always people parting out cars on here and on the facebook page.
if you look through th stickies on this forum you will find an article about the things you should look at when you get your tercel like transmission oils, sway bar end etc.
RCinNM
Post by RCinNM »
Thank you!
MrWrench
Post by MrWrench »
I have a set of side mirrors for sale if you're interested.
PM me
1983 AV-II Sprinter Carib.
