Front Upper Strut Braces: Custom Fabricated: $125 Order Now!
4wdchico
My tercel:: 1985 tercel 4wd
Re: Front Upper Strut Braces: Custom Fabricated: $125 Order
Post by 4wdchico » Wed Dec 01, 2010 10:23 am
Good Idea putting it behind the A/F housing, looks nice.
So the brace mounts to the inside and rear bolt of the strut mount?
Post by ARCHINSTL » Wed Dec 01, 2010 12:09 pm
I brightened the photo somewhat for a clearer exposition:
> > Left click on it to enlarge < <
St6fan
My tercel:: 1987
Post by St6fan » Thu Dec 02, 2010 12:34 pm
4wdchico wrote:Good Idea putting it behind the A/F housing, looks nice.
Correct.
So, I just got done installing the KYBs front and rear - much easier than I'd anticipated.
The car now handles like a total dream, a complete night and day difference. Even with the stock BMX wheels with cheap tires, the sudden increase in grip boarders on the unbelievable. Understeer is almost completely gone. Can't wait to get some new wheels on there with a wider track - should be incredible.
Of all the cars I've owned, these modifications have made the most difference to handling when balanced against time (four hours in total I guess) and $325 for the brace and shocks. My fiend who came out on the first test drive called the car The Slug on Rails. I like that! :)
1986 Tercel 4WD Slug-On-Rails
1969 Miro 12' Skiff with 15HP Evinrude
2006 Prius (Sorry, but I totally love it)
Post by ARCHINSTL » Thu Dec 02, 2010 1:04 pm
Well - QUITE an endorsement! I am saving...
Did you use KYB Gas-Adjust or GR2 on the rear? I used GR2 (and all new sway and Panhard bushings) and am happy.
St6fan
My tercel:: 1987
Post by St6fan » Thu Dec 02, 2010 1:20 pm
GR2. I wasn't told about another option when I ordered them at NAPA.
I'm going to get a quote for anti-roll bars and some sort of subframe lock - any idea where best to try further bracing on the car?
Post by ARCHINSTL » Thu Dec 02, 2010 2:01 pm
There are varying opinions here on GR2 v. Gas-Adjust. I went with GR2 after weighing advice (for MY type of usage) from Highlander, who has a set of each on his two Wagons. See http://www.tercel4wd.com/viewtopic.php? ... cks#p42970
Post by Petros » Thu Dec 02, 2010 2:16 pm
St6fan wrote:I'm going to get a quote for anti-roll bars and some sort of subframe lock - any idea where best to try further bracing on the car?
It would be best if you can make the anti-roll bars adjustable so you can compensate for changing the spring stiffness later. The rear one is easiest to make adjustable since it uses a link at the end.
The front one also doubles as a drag strut, not the best way to locate the front wheel. It is simple, but most manufacutres, including Toyota, have long ago abandoned this type of suspension. I was thinking of working something up, once I am done with my 4age swap, that uses a separate drag strut that just pivots (like the rwd corolla uses) and than have a completely separate anti-roll bar, one that is adjustable. This means making new mounts for all these parts, but I thing it will improve both handling and the ride quality.
AS far as stiffening the subframe, you can make stronger diagonal braces that run from the frame to the cross member. These are pretty lightweight tubes right now, often they get damaged and or removed. the 2wd version does not have these braces. I have also seen a strut, similar to the strut tower brace, that goes from the inner lower suspension points, tying the left and right lower lateral link mounting points together. I do not know if this will reduce ground clearance, but it should stiffen the lower suspenion mount.
SynthDesign
Post by SynthDesign » Thu Dec 02, 2010 3:12 pm
I got a few ideas. Hopefully, I'll see ya this weekend and maybe I can show ya what I'm thinkin.
85 Toyota MR2 (Blu)
86 Toyota Tercel 4WD DLX for sale (BluBoy)
86 Toyota Tercel SR5 Canadian Import (Galena)
83 Mazda RX-7 Mariah Widebody
Wait I have more
CathodeRayTube
My tercel:: 1985 4x4 Automatic - restored
Post by CathodeRayTube » Sun Apr 03, 2011 6:52 pm
I would also be interested in this...However my needs are probably going to be pretty different and il have to fabricate it myself or have somebody else custom make it. My plan was to have a strut brace like this, but also have it function as a support for a top-mounted intercooler for the turbo diesel engine...
85 T4 DX 4x4 Automatic
83 T4 SR5 - junker/parts
94 4Runner V6
86 Mercury Grand Marquis
88 Lincoln Town Car
90 Yugo GV+
peter_tuning
Post by peter_tuning » Mon Apr 04, 2011 3:13 am
му
garyfish
Post by garyfish » Sat Jun 22, 2013 10:24 pm
Anybody know if these strut braces still available? I'm interested in purchasing one (definitely), maybe two.
I PM'ed St6fan a month ago, and no response... it's been about 2.5 years since he last posted in this thread, and 2+ years since there's been any activity at all on this topic.
1987 Tercel DLX 4WD wagon, 6-speed manual, 248K -- got this one running Jan. 2015 (had been sitting for 2 years)
Post by Petros » Sat Jun 22, 2013 11:20 pm
St6fan moved from Port Townsend WA to California several years ago and I do not think he has been on the list since. You will have to fab your own, modify a strut tower brace that comes stock in an MR2 (it needs to be shortened several inches to fit in the Tercel), or find something else that is close and alter it to fit like I did (I found one from a Nissan at a PicknPull cheap, and I extensively modified it to make it fit).
SynthDesign
Post by SynthDesign » Sun Jun 23, 2013 11:01 pm
Finding an AW11 (85-89 MR2) non sunroof sway bar is darn hard to come by now it seems. Ebay only it and never in a junk yard anymore.
85 Toyota MR2 (Blu)
Wait I have more
