Need parts in Ontario
3A-C, there's an '85 model SR5 at the junkyard here in Nashville. I've taken some trim pieces and the roof rack off of it, and tried to get the trailer hitch, but haven't been able to get it off yet. What is it you're needing ?? I think everything under the front end is still there.
I am planning on going back to the yard tomorrow....need to snag a couple more trim pieces, and going to take some liquid wrench or some such stuff and try to get that trailer hitch off. I will look at the crossmember and see if I can get it for you. Do you just need the crossmember ? or are there other pieces that are necessary as well ?
