trasmission parts
86tercelOG
My tercel:: 1986 Toyota Tercel SR5. Completely stock
trasmission parts
Post by 86tercelOG »
does anyone have any transmission parts for a 1986 tercel wagon sr5.... need the shifter fork in the internals...
Re: trasmission parts
that pile of trans parts looks to be the ealier 83-84, it has steel shift forks, not the later style aluminum allow forks. it is also likely the 3.73:1 ring and pinion ratio. those parts are well worth getting to save them to keep a T4wd on the road, but unless you swap out the whole gear box, those shift forks may not work in the 86 trans.
contact forum member Xridneh about trans parts, he likely has the biggest inventory. he has even repaired worn out aluminum shift forks. had them built up with weld and than machined back to spec.
