'86 T4WD SR5 wagon added to wrecking yard in Rancho Cordova, CA on 8/11/2020
garyfish
Post by garyfish » Thu Aug 13, 2020 1:11 am
somebody stripped the grille, headlights and hood from this wagon before the yard got around to taking a photo of it!
https://row52.com/Vehicle/Index/JT2AL35WXG0215656
1987 Tercel DLX 4WD wagon, 6-speed manual, 260K -- got this one running Jan. 2015 (had been sitting for 2 years); this has been my daily driver since 2016
Intermodal
Re: '86 T4WD SR5 wagon added to wrecking yard in Rancho Cordova, CA on 8/11/2020
Post by Intermodal » Thu Aug 13, 2020 8:14 am
I’ll be adding to the carnage today! So much plastic on mine has but the dust so I’m hoping this one has what I need. It’s the same exterior color but a different year, so hopefully the interior matches!
Intermodal
Post by Intermodal » Thu Aug 13, 2020 2:05 pm
Cruise control! Seems like everything is there, but one plastic cable surround coming out of the “module” under the hood is broken.
The hood is on the roof. Pretty much all of the interior is gone, save for window trim, Rear door panels, rear seat backs and headliner.
I got a remanufactured (and only partially installed?) Holley carb, the driver door, tail lights, valve cover, and the dash surround. I left the cruise control switch, but took all the others.
The valve cover was on finger tight and there was fresh oil on the rockers. I suspect the motor was at least partially rebuilt due to the fact that everything was so loose and the cam looked like it might’ve been replaced. Wasn’t someone on here looking for a cam?
I think this was either a parts car or a project car for a very long time.
Oh also it has a sunroof! But someone grabbed the controls for it.
garyfish
Post by garyfish » Thu Aug 13, 2020 6:18 pm
nice score!
Post by Mattel » Thu Aug 13, 2020 6:48 pm
If the sunroof is not rusty then it is worth grabbing. without the switch just use a large flat blade on the large screw head where the switch was to open and then you can unscrew the panel from above.
Intermodal
Post by Intermodal » Thu Aug 13, 2020 10:49 pm
I thought about getting some of those goodies to resell but opted to leave it, as my car does not have a sunroof. I am definitely thinking of going back for the ac parts, though.
Also, if anyone has the gumption to pull a transmission on a day projected to be 111 degrees, this one felt like it would be worth the trouble.
Post by Mattel » Thu Aug 13, 2020 11:12 pm
Some parts are getting rare, lights, good condition interiors, trim and gearboxes, inclometers Steel sunroof without rust should be able to resell on here at some time. might be worth seeing what they want for it! I always grab small screws and knobs, bulbs as well.
The Professor
Post by The Professor » Fri Aug 14, 2020 9:01 am
Would you be willing to grab the windshield wiper switch for me, please, along with any control module that it's attached to? I would also be interested in the cruise control parts if you're able to get the complete setup.
Thanks!
1984 Subaru Turbo-Traction wagon & Turbo-Traction hardtop
1987 Subaru RX 3-door, x2
Intermodal
Post by Intermodal » Sat Aug 15, 2020 1:37 am
Professor, I’ll look into what it takes to remove the switch and let you know if I’m up for it; we’re looking at 110+ for the next few days so I think I’ll be waiting a while before I return. I will get back to you within a week!
