AE86 & AE82 Corolla parts swapping to AL25 Tercels?
Kozuto_98
My tercel:: 1987 SR5 Wagon
Re: AE86 & AE82 Corolla parts swapping to AL25 Tercels?
Post by Kozuto_98 » Sun Sep 13, 2020 4:51 pm
atoyta wrote:
Sat Sep 12, 2020 10:24 pm
In my experience the KYB shocks are a little stiffer than others I have used.
Good to know. I honestly thought I was imagining things with the new shocks. They seemed way stiffer than normal.
1987 Tercel Wagon SR5 4WD
2016 Honda Civic W/ light head work on KTuner V2 (187HP)
Erikwi
My tercel:: 1988 stock auto
Post by Erikwi » Mon Sep 14, 2020 1:52 pm
your panhard bar bushing looks wore out
Kozuto_98
Post by Kozuto_98 » Tue Sep 15, 2020 5:55 pm
Yeah they could use a replacement soon. They're not gone enough to have a bunch of play, yet.
Not sure if the bushings can still be found new.
The Professor
Post by The Professor » Wed Sep 16, 2020 10:46 am
One end is still available in rubber, the other end is SuperPro-only.
1975 Subaru SuperStar wagon
1987 Subaru RX 3-door
1987 Subaru RX Type-RA 3-door
1987 Toyota Tercel SR5 wagon
1999 Subaru Forester S
2002 Subaru WRX sedan
Erikwi
Post by Erikwi » Wed Sep 16, 2020 11:18 am
whiteline also makes it.
https://www.suspension.com/products/toyota_tercel_1985
The Professor
Post by The Professor » Thu Sep 17, 2020 9:03 am
After my experience with Whiteline products and how they've let their quality slip, there is a reason I didn't mention that brand.
ALiveSR5
My tercel:: 1985, SR5, 4WD, 6-speed manual, Wagon.
Post by ALiveSR5 » Sun Sep 20, 2020 8:56 pm
As may be known, the Tercel IS a Corolla, built mostly from Corolla parts, though I do not know specifically which are interchangeable.
Many parts for my wife's former 1991 Corolla fit my 1985 Tercel, for example, which was sometimes convenient.
This comparison of parts for the two models is quite interesting.
Unfortunately, the Toyota parts counter people that I worked with did not know what was interchangeable, even though there were quite a few years that both Corolla and Tercel interchangeable parts were available. When the availability of genuine Toyota 1985 Tercel parts dried up, then aftermarket parts were gone... well you know.
A curiosity would be the last model year of Corolla parts that would fit Tercels 1983-1987 and their availability.
Just musing, not expecting a reply. :wink:
No other vehicle that I have ever owned had a heart and soul like my 1985 Tercel SR5 4WD Wagon. :D
Great minds may think alike but it is the doers who see their visions become reality. :?
Post by Petros » Tue Sep 22, 2020 12:47 am
Toyota is kind of odd about parts interchangeability, if they get a factory authorization with a "superseded" part number, they will sell it to you. but if you ask for the Tercel part, and it is NLA, and than ask for a part number that is from a corolla, they will tell you they are not "authorized" to sell it to you.
Might be liability or something, but they will not sell it if they know you are going to use it on a different car. the corolla fuel filter for example, for the same year Tercel, can be interchanged. oddly the corolla one is larger and costs less too, but they are not authorized to sell it to you (the metal clip that holds need to be bent a bit to make the larger fuel filter fit). if you ask for TErcel windshield wiper motor, it too is NLA, but the corolla one is identical, except the connector (which you can swap out with your old connector by slipping the contacts out, no alterations needed) I just do not see the hazard in it, but they will tell you they can not sell you the part to install in your tercel. so you have to lie to them for what it is for, if trying to buy dealer parts, which I very rarely do anyway.
ALiveSR5
Post by ALiveSR5 » Tue Sep 22, 2020 8:04 am
I wondered about that. Your explanation makes a lot of sense. Thank you for clarifying this puzzling parts predicament.
JDNightFox
My tercel:: 1986 SR5 / 1987 SR5
Post by JDNightFox » Thu Sep 24, 2020 7:54 pm
I would like longer rear axle links so that I can give the rear tire more clearance
Post by NWMO » Thu Sep 24, 2020 9:26 pm
Just mounted mine this evening.
I didn’t lengthen the top arms, but I don’t think the angle change is significant. I also lengthened the rear drive shaft 1”, I pick it up tomorrow. I will post pics after I get the engine back in and get the car out of my small garage.
