AE86 & AE82 Corolla parts swapping to AL25 Tercels?
Kozuto_98
My tercel:: 1987 SR5 Wagon
Post by Kozuto_98 » Sat Jun 27, 2020 10:34 am
So a couple weeks ago I was tearing apart the rear suspension on my AL25 Tercel with a friend when she mentioned that the rear axle and suspension looks identical to her 1984 Corolla GTS AE86.
After we finished tearing down my wagon we jacked up her Corolla to have a look, and sure enough it's the same!
This got me thinking about parts swapping and parts sourcing, so I decided to take a look on Toyota's parts website, and here's what I found!
Here's the diagram for AL25 Tercel wagons
Here's the diagram for AE86 Corollas
It's pretty much the same setup!
Now I will point out that there is some slight variations in parts numbers.
What I was mainly looking at were the coil springs, as I've been having a tough time tracking down new ones as mine are completely shot on my wagon.
I ordered some stock replacement AE86 springs from rockauto to test this theory and they fit right in! I think the part number variation is due to a difference in the spring stiffness.
If I had the time and money to test more of the aftermarket parts for AE86 Corollas on these wagons I would, as I'd like to see if things like coilovers or link arms would also swap over, and maybe even swapping the rear brakes from drums to AE86 disc brakes.
As for sourcing some new front springs, I've sadly run into the same parts availability troubles.
But here's where I noticed another similarity to other Toyota models. A few years ago I owned a 1987 Corolla FX16 AE82 that also needed it's fair share of work. When I was tearing apart the front suspension on my AL25 tercel last week I noticed that the shock and spring setup looked very close to what my old Corolla FX16 had. The main difference seems to be the knuckle, control arm design, and sway bar placement.
So again, I went back to Toyota's parts website to have a look, and here's what I found.
Here's the diagram for AE82 Corolla FX16s
The shock and spring design seem to be the same. However, like with the AE86 springs, there is also a parts number variation with the springs.
I have yet to order the front springs to see if they will for sure fit, but I will make sure to update this post when the time comes!
If anyone knows of other parts that can be swapped over to these Tercel wagons please let me know! These cars aren't getting younger and parts must be found!
1987 Tercel Wagon SR5 4WD
2016 Honda Civic W/ light head work on KTuner V2 (187HP)
DanDelion
My tercel:: 1985 SR5 Wagon
Re: AE86 & AE82 Corolla parts swapping to AL25 Tercels?
Post by DanDelion » Wed Sep 02, 2020 6:51 pm
How has your luck been with AE86 parts?
I'm replacing the whole suspension and I cannot find coils for my 1985 Tercel SR5. Going to order the Ae86 front and back and see if they work.
Kozuto_98
Post by Kozuto_98 » Wed Sep 02, 2020 10:10 pm
I haven't tried the rear shocks and coils yet, but looking at the new and old ones they are for sure the same, but the spring rate is for sure stiffer with the AE86 springs. I Don't think any of the front suspension will work from the AE86 and I have yet to actually order AE82 springs to test my theory.
I've also had a slight suspicion that KP62 Starlet parts might possibly work but I need to look into that more.
Erikwi
My tercel:: 1988 stock auto
Post by Erikwi » Thu Sep 03, 2020 10:39 am
i saw on ebay a company in Australia was making custom springs at a reasonable price
Kozuto_98
Post by Kozuto_98 » Thu Sep 03, 2020 12:20 pm
Do you know if the seller still has them for sale?
Post by Petros » Thu Sep 03, 2020 5:22 pm
I had made a visual inspection of the GTS corrolla RWD and found the rear axles and suspension almost identical. it means the performance rear suspension parts for the AE86 corolla should also fit in the Tercel4wd wagon. but I have nto tried it yet.
be wary of the front suspension parts, the bushings should all be the same, but the strut could be a different length, but otherwise identical.
Kozuto_98
Post by Kozuto_98 » Fri Sep 04, 2020 5:43 am
If the front springs from the GTS at least match up that would be awesome for finding parts!
Erikwi
Post by Erikwi » Sat Sep 05, 2020 1:18 pm
have not checked
here is some he has listed
https://www.ebay.com/itm/FRONT-REAR-STA ... Swr~lYoVJQ
since they make them in house, ask them
Erikwi
Post by Erikwi » Sat Sep 05, 2020 2:39 pm
can anyone verify this is the part for the rear swaybar mount
it looks right in the picture
https://www.aliexpress.com/item/3297037 ... 347buk5zOS
Kozuto_98
Post by Kozuto_98 » Sat Sep 05, 2020 7:21 pm
Personally I don't think it will work, but, it's always worth trying
Kozuto_98
Post by Kozuto_98 » Sat Sep 12, 2020 4:29 am
I FInally got around to putting the AE86 shocks and springs into my wagon. I can now say for sure that they work.
However, the shocks and springs are a bit more stiff than actual Tercel ones so keep that in mind.
I went with KYB shocks and factory AE86 springs. Next I want to see if the rear sway bar links swap over.
Post by NWMO » Sat Sep 12, 2020 9:33 am
Koz,
I got rid of the rear sway bar all together and don’t miss it.
Kozuto_98
Post by Kozuto_98 » Sat Sep 12, 2020 10:28 am
Koz,
Nice, does it make much difference?
Post by NWMO » Sat Sep 12, 2020 3:33 pm
I do not notice much difference at all.
atoyta
My tercel:: 3 wagons now
Post by atoyta » Sat Sep 12, 2020 10:24 pm
In my experience the KYB shocks are a little stiffer than others I have used.
