4WD fuel pickup line?
dirklc
My tercel:: 1984 Tercel 4WD SR5
Post by dirklc » Thu Jun 25, 2020 10:40 am
Hello,
I need to replace the fuel pickup line on top of the fuel tank (so the three metal lines going into the tank).
This part is still available for FWD Tercels. I ordered this part and it's a drop-in replacement for our T4WD tank but the pick-up line doesn't reach close to the bottom of the 4WD tank (I believe the FWD and 4WD have different tank capacities).
Does anyone know if the 4WD fuel pickup line is still available? If not, then I wonder if I could modify the FWD part...maybe add a length of fuel hose with a mesh end, similar to what you might see on a boat fuel tank?
Any advice would be most appreciated!
Best,
Dirk
1984 Tercel 4WD SR5
1985 Range Rover
1998 Toyota T100 4WD SR5
1995 Toyota T100 4WD SR5
LowBuckCanuck
Re: 4WD fuel pickup line?
Post by LowBuckCanuck » Sat Jun 27, 2020 9:33 am
I need a source for one too. I tried modifying a 2wd one and it works, but comes into contact with my float so the gauge won't read below 1/2 tank. Frustrating.
dirklc
Post by dirklc » Tue Jun 30, 2020 3:44 pm
Yeah, that's what I'm concerned about as well. I will play around with it a bit this weekend and will let you know if I come up with a fix. If I just use rubber fuel hose and a mesh end then I think I could route it away from the fuel level sender...
1984 Tercel 4WD SR5
1985 Range Rover
SirFoxx
Post by SirFoxx » Wed Jul 01, 2020 7:33 pm
When it comes time, I am just going to take mine to a shop and have it fixed / modified. My '82 tercel will not idle if its below half a tank, leading me to believe theres a hole or crack in the pickup tube. I am going to have mine modified since I will be dropping a 4agte into it, and EFI systems need 3/8" line at a minimum.
1988 DLX Tercel Wagon w/ weber (RIP)
1985 4wd Tercel SR5 (RIP)
1981 Toyota Tercel
Post by Petros » Thu Jul 02, 2020 1:03 am
the FWD model the tank is under the rear seat, completely different shaped tank. the pickup from many totoytas should fit, they are all very similar.
I wonder if the same year carberated corolla fuel pick up will fit, the tank is very similar in location and size and shape as the tercel4wd. I have one from a fuel injected corolla and was going to see if I can get it into my project 4age swap Tercel so I can have the high pressure EFI fuel pump inside the tank. looks like it will all fit fine, I have not tried it though. the tanks look almost identical.
OTHO, can you bend the pick up lower in the tank? anyway you can get it down to near the bottom the better. it is a low suction line, so there is no special requirements. only that the fuel pump can suck fuel up it.
marlinh
My tercel:: 'Everett' Blue mint 4WD wagon and 'Rocky' 86 4WD Wagon
Post by marlinh » Thu Jul 02, 2020 8:39 am
Can you post a picture of the two pick ups side by side?
I believe the tubes are silver soldered (different process than soldering) to the cover. You could fabricate a new tube using the old one as a template and solder it onto the new pick up.
LowBuckCanuck
Post by LowBuckCanuck » Mon Jul 06, 2020 7:22 am
I did try bending my 2wd pickup, and it is feasible to make it work. The real issue is that all the tubes are clocked differently on the 4wd tank, which means you have to put a twist in the lines (prone to snapping). Apparently I didn't do that well enough, because my float contacts the fuel pickup. Also my tank is a pain to fill so I think I messed up the vent too :(
