Front marker for 87’-88’?? Or 2WD?
Hey all,
Doesn’t fit 83’ or 85’, significantly longer bottom. What does it fit?
rer233
My tercel:: Multiple
Re: Front marker for 87’-88’?? Or 2WD?
Post by rer233 »
Probably '83-'86 FWD- they were different from the T4s.
Theartofthetercel
My tercel:: 1983 Toyota Tercel 4wd
Post by Theartofthetercel »
I think the orange lens is the same if your housing is still good you can swap it over.
The bottom part of the lense is significantly longer, I should have compared with the JY 2WD in KC.
on the 2wd top edge of the front bumper is a little lower (the bumpers are different because the 4wd has 25 mm longer front struts and rides higher)
That means the trim along the front plastic parts are a bit different. I have wondered if you can just trim off the lower edge of the marking light assembly to make it work, because it appears similar in all other ways.
