Hi all!
New to the forum, but not to the Tercel love. Recently got my second (first had an unfortunate wheel bearing incident, but holds a dear place in my heart) and want to start cleaning it up a bit.
It's really in pretty good cosmetic shape aside from the driver side parking lamp being busted. While the bulb is still intact and works, I have been looking for a new assembly and been having a hard time.
Does anyone happen to have one sitting around they would be willing to sell or have an alternative?
Thanks!
LH Parking/Clearance lamp
- My tercel:: 1988 white 4WD, just beginning to tinker
My Tercels will all be named Studs after my G'ma thought I was talking about Studs Terkel when I told her my car was a Toyota Tercel.
Studs (1988 4WD, Blue w/ plaid) 2012-2014
Studs II (Placeholder name for a film editing machine I got shortly after the death of Studs) *not a Tercel
Studs III (1988 4WD, White) 2017-
Studs IV (1987 4WD, Gray) 2019-
Re: LH Parking/Clearance lamp
if your T4wd uses the composite headlamp, it has a marker light common to only the '87-88 model years. Hard to find since Toyota was already phasing out that model of Tercel.
you might go buy a lens repair kit from the Auto parts store and see if you can rebuild it so it is acceptable until you can locate a replacement. The kit has flexible plastic panels of amber and red to use to patch broken marker/indicator lights. Used one on a Pathfinder I used to own and you could hardly notice the repair.
Thanks for the tip, that should be a good placeholder.
