FS: 83 Tercel 4WD transmission + Front Differential
Tman312
My tercel:: 1985 Tercel 4WD
Post by Tman312 » Sun Dec 09, 2018 1:23 pm
Selling off my spare trans as I no longer need it, worked fine just when I did the 4ac swap I used a different trans.
Still attached to front diff
Located in Auburn, WA
$250
Tman312
Re: FS: 83 Tercel 4WD transmission + Front Differential
Post by Tman312 » Wed Jan 02, 2019 9:22 pm
Price drop, 200.
Rellison
My tercel:: 85 4wd sr5 wagon
Post by Rellison » Mon Jan 07, 2019 10:23 am
Do you know if this particular trans will work on an 85 4wd sr5 wagon? If so ill most likely take it
C130
My tercel:: 1984 SR5 280K Lift and 195 75 14.
Post by C130 » Mon Jan 07, 2019 2:12 pm
Beat me to it, I also have an 85 4WD SR5. If transaction with Rellison falls through I would be interested. P/N's off the trans would be great as well. PM me because I haven't been getting notifications otherwise. Thanks.
Post by Petros » Mon Jan 07, 2019 8:30 pm
The gear box in the trans will bolt up no problem, there are slightly different connectors for the back up light, and there is no "EL" indicator on the early models. changing the connector is not a problem.
The diff uses different ratios on '83-84, and 85 and later transaxle assembly. If your front diff assembly is in good condition than you will need to swap that out the whole bellhousing/front diff assy to keep the front/rear diff ratio the same. or you can use the front diff assembly on the early transaxle, and swap out the rear diff assembly with the 3.73:1 rear diff to it will match the new front diff ratio.
I would advise against trying to swap out the ring and pinion, it can be done but is a big complicated job to get the gear lash correct. even experienced mechanics can mess that up. do it as a complete assembly where you do not change the clearance between the ring and pinion gears.
SinusoidalTendencies
My tercel:: 87 4wd wagon
Post by SinusoidalTendencies » Sun Dec 22, 2019 4:26 pm
was this sold?
Abletobecain
Post by Abletobecain » Fri Jan 03, 2020 10:17 am
Following...if it's not sold and ST doesn't get it...I'd buy it. I'm right across the water from Auburn...could come get it any time.
2007 Tundra Limited Crewmax 4x4 ("Tetsuo Shima"/Hauler) SOLD :cry:
1987 DLX Tercel Wagon 4WD ("Lil Red") SOLD :)
