ISO: Wiper switch assembly from a 1985-88 SR5 wagon
garyfish
Post by garyfish » Mon Nov 12, 2018 4:29 pm
I've been wanting to get a wiper switch assembly out of an SR5 (with the intermittent setting) as an upgrade for my '87 T4WD DLX wagon
I recently learned on this Forum that only the (edit) 1985 through '88 SR5's have the proper 5-pin connector for the wiper motor... earlier SR5's have a 4-pin connector which will not work without modifications
can anybody out there help me with this? ... if so, post here or PM me
1987 Tercel DLX 4WD wagon, 6-speed manual, 251K -- got this one running Jan. 2015 (had been sitting for 2 years)
rer233
My tercel:: Multiple
Re: ISO: Wiper switch assembly from a 1987-88 SR5 wagon
Post by rer233 » Mon Nov 12, 2018 7:07 pm
Gary- '85 & '86 SR5s also have the proper switch ass'ys- only '83 & '84's have 4-pin wiper motor connectors.
garyfish
Re: ISO: Wiper switch assembly from a 1985-88 SR5 wagon
Post by garyfish » Mon Nov 12, 2018 9:10 pm
rer233 -- thanks for the clarification...
I'll see if I can edit the title of this thread
Post by irowiki » Tue Nov 13, 2018 9:58 am
Good news: I'm *sure* I have one.
Bad news: It's buried in the garage which is on the to-do list. :lol:
I'll let you know.
81 Coachmen RV, 65k miles
95 Camry Wagon, 135k miles
04 Camry Sedan, 213k miles
garyfish
Post by garyfish » Tue Nov 13, 2018 1:55 pm
^^^ thank you!
I can wait. PM'ed you with my snail-mail address.
Abletobecain
Post by Abletobecain » Fri Jan 11, 2019 4:25 pm
Did you get this figured out?
I pulled the switch assembly off of an 83 SR5 and plugged it into my 83 DLX but the intermittent failed to work. I recently pulled the motor as well but I haven't tried to install it yet. Would swapping the motor along with the switch give me intermittent wipers?
It's such a simple feature that is easily overlooked until you don't have it.
2007 Tundra Limited Crewmax 4x4 ("Tetsuo Shima"/Hauler)
1987 SR5 Tercel Wagon 4WD ("Sprocket"/Daily Backup)
Post by Petros » Sun Jan 13, 2019 9:31 pm
not likely the motor is the cause. but I am not even sure of the wiring logic of the system, I thought the intermittent switch was in the control stock, not in the motor.
you might check the part number on the wiper motor, if it is the same for both SR5 and DLX, than it would not be the motor.
