Needed; Rear Differential ("Pig") for '84 Tercel
DAYoung
Post by DAYoung »
I think anything from '82 to'86 (Gen II) should work. Even an equivalent vintage RWD Corolla? I do not need the axle housing or axles but that is the only way to get the Diff, that is OK too.
Re: Needed; Rear Differential ("Pig") for '84 Tercel
there are at least three different ring and pinion gear ratios in that year range ('82-86). the '84 t4wd with manual trans should have the 3.73:1 ratio, the auto trans has something else, I think a 3.89:1 (or something similar). The '85 and newer used 4.1:1 ring and pinion ratio.
So unless you have a selection of the front drive gear ratios, you will need to match the front and rear ratios. you will want either a '83 or '84 rear diff assembly with the 3.73:1, unless you have an auto transmission Tercel4wd. That assembly BTW is called a third member.
DAYoung
Post by DAYoung »
Thank you Petros,
I am using the axle in a RWD (only) kit car so I do not have to match any FWD Diff ratio. I would actually prefer the 4.1:1 ratio but they will all work for me as long as they will bolt into the '84 Tercel axle housing & axles I have.
Do you know if and what Corolla "Third-Members" might also work?
the RWD corolla should work, I am pretty sure the Tercel4wd used the corolla rear axle. the DX model only, not the GTS, that uses a larger diff assembly.
