Tercel Part blowout! EVERYTHING must go!
BAMF
My tercel:: 84' 4WD SR5 Wagon
Re: Tercel Part blowout! EVERYTHING must go!
Post by BAMF » Mon Apr 17, 2017 11:29 pm
I am very interested in the entire front end steering kit as well as both the CV axles if they're not remans, the 4WD shifter seal and various other things. Im actually moving to Porland, OR next week from Albuquerque and would go right through Farmington.
BAMF
Post by BAMF » Mon Apr 17, 2017 11:51 pm
Petros you want the whole thing?! Lol. Can I convince you to buy the whole shebang minus a front end steering kit, both CV axles and a 4WD shifter seal plus various other things? I will have a lot of extra room in the moving truck and would gladly bring whatever you buy to Porland and could ship/meet from there.
Post by Petros » Tue Apr 18, 2017 12:31 am
yes, sure I would. What ever you do not need I will be happy to buy from you. I will use them all eventually. I do not really need any used parts, or the CV axles (I have my own supply already).
I drive thorough Portland several times a year going to California to visit family. I can get it all on one of those trips, especially if I can crash on a spare bed or couch for the night. I may be going to Calif in September in fact.
BAMF
Post by BAMF » Tue Apr 18, 2017 9:49 pm
Excellent! Irowiki whats your schedule looking like next week? Petros I would be more than happy to host you if your coming through Portland, just lemme know!
4wdEconoBox
My tercel:: 1985 Toyota Tercel SR5 4WD
Post by 4wdEconoBox » Tue Apr 18, 2017 10:09 pm
I'm still needing a good drivers side window regulator if anyone has one!
LOSTFISH
My tercel:: BLUE 87
Post by LOSTFISH » Wed Apr 19, 2017 2:46 pm
in addition to the 87 headlamps im also interested in the distributor o-ring, and valve stems and seals
helipilot77
My tercel:: 1984 SR5 wagon
Post by helipilot77 » Wed Apr 19, 2017 4:15 pm
4wdEconoBox wrote:I'm still needing a good drivers side window regulator if anyone has one!
4wdEconobox - would you be interested in the drivers side window regulator I have if I repaired the worn teeth? I was thinking about building the material back up with weld. The supply of O.G. regulators is dwindling. I would hate throw one away if I can fix it.
. / TOYOTA
./_| |/|/ |]
Post by irowiki » Thu Apr 20, 2017 11:32 am
OK guys sorry!
I'm somewhat back. Life is nuts!
@Buzzard67: I have so many random pieces but it'll be a while. I will save a carb rebuild kit for you. I'm thinking $15 plus shipping
@Peter: You said you wanted everything first or can I parcel out things like the valves to Marlene?
@TheProfessor: How about $15 for timing belt kit, $10 for water pump, $10 for a carb, plus shipping? Depending on the shipping I'd probably throw one more carb in just in case.
@lostfish: make me an offer for both 87 headlight assemblies, I might put these up for "auction" since so many people want them!
By "valve stems and seals" you mean just the valve stems? How many?
@bamph: wow, OK, I should be in town next week, what day are you coming through? I'm pretty sure the CV axles were new. I'll start pricing the main things on your list.
@4wdEconoBox I bet I have one somewhere but it is in the endless boxes of parts I won't be able to go through for a while
81 Coachmen RV, 70k miles
95 Camry Wagon, 153k miles
04 Camry Sedan, 250k miles
Post by irowiki » Thu Apr 20, 2017 12:00 pm
viewtopic.php?f=3&t=12606
For the 87 headlamps
BAMF
Post by BAMF » Thu Apr 20, 2017 9:55 pm
Figured you were busy! I was planning to leave ABQ Wednesday the 26 late morning but im flexible on when exactly id be coming through Farmington if it helps you. If the axles are not new but good used condition id still be interested!
Vienna
Post by Vienna » Thu Apr 20, 2017 10:40 pm
BAMF wrote:Figured you were busy! I was planning to leave ABQ Wednesday the 26 late morning but im flexible on when exactly id be coming through Farmington if it helps you. If the axles are not new but good used condition id still be interested!
Irowiki's wife posting for him!
We're pretty flexible as well since we have no travel plans until the 29th.
Post by irowiki » Fri Apr 21, 2017 11:33 am
The axles are brand new, not reman. I bought them to eventually install in our FWD wagon because at the time we thought we were keeping her forever. Alas, life changes...
BAMF
Post by BAMF » Fri Apr 21, 2017 10:54 pm
I am unfamiliar with what parts are shared between FWD and 4WD, are the axles the same?
rer233
My tercel:: Multiple
Post by rer233 » Sat Apr 22, 2017 12:11 am
Yes.
BAMF
Post by BAMF » Sat Apr 22, 2017 8:38 pm
Thanks! Irowiki im not exactly sure what time of day I will be coming through Farmington, but id imagine early afternoon, will let you know
