Wanted:Emissions parts
- My tercel:: 1984 Toyota Tercel SR5
I am in need of parts to help my Tercel pass emissions in CO. I have a Tercel 4wd wagon SR5 with a rebuilt 4A engine (it originally came with a 3AC).
After failing the emissions test, I took it into my mechanic and he thought I was missing the Air Suction Valve and Reed.
Can anyone tell from the photos if I'm missing anything else? I would love any advice or if you have a parts car and have the AS valve, I would love to chat!
- Mark
Re: Wanted:Emissions parts
Not all catalytic converters had the air suction system. You can tell by looking at your cat and seeing if there is a pipe sticking out of the middle pointing towards the driver's side of the car. This sucks in fresh air to the middle of the cat when the engine is running. The reed valve just prevents exhaust from flowing out the pipe the wrong way when the engine is at idle. I don't think that missing the reed valve would affect emissions. It would just make the exhaust louder at idle like there was a hole in it.
- Mark
I just noticed in your last picture that you are pointing at what looks to be part of the AS pipe. Unless it's capped off or blocked, I don't see how it would affect emissions just by missing the reed valve.
- My tercel:: 1984 Toyota Tercel SR 5 custom aluminum rims 4 a motor custom rims Bluetooth stereo system
Please do me a favor and take a photo with the air cleaner off it doesn't look like you have very many vacuum lines on yours and ours all have a cluster of vacuum lines
That's my new goal
That's my new goal
That's my new goal
That's my new goal
Definitely looks like a broken TVSV which would just kill emissions.
- Gottolovem
Your very first photo shows a broken TVSV that part alone has 5 vacuum lines running from it and you have none of them I can see in that photo.
Your going to need to replace that TVSV (expensive) then you need to learn your entire vac system. Your car should run MUCH better when your done.
- My tercel:: None
It's hard to tell from the pictures, but it seems like it's also missing other emissions components like the EBCV (I don't see those two hoses running to the carb) and the vacuum switches. All of which are important part of the electronic feedback system, which reduces emissions under cruise conditions.
2015 Honda Fit EX "Malachi"
Thanks for all your help - here it is without the air box.
And Mark, yes mine has that other pipe coming off the cat heading forward but stops at the rubber tube. I think I need the pipe forward which includes that valve that's about the size of a 32oz can of tomatoes.
Here's the back side, I think this must be a new carb - my tube coming from my charcoal canister past the outer vent control valve connects to nothing. Looks like I'm also missing an EGR vacuum modulator. Gottolovem I agree I need to learn the vac system.
Thank you for sending those photos that you did with the carb air cleaner off the you're missing a great deal of vacuum lines that go all the way around the carburetor
That's my new goal
That's my new goal
- BaileySims
I have some emissions stuff in a box somewhere in the attic. I'll look into it today and see what I have. Since switching to a weber and not having emissions here, I didn't need much of it.
WAGON MAFIA.
Blood, sweat and beers.
Ouch...
Yeah I have a large amount of the things you might need but be warned, trying to retrofit stuff onto the car is hard. I speak from experience.
You will probably need another carburetor too as that one probably has key ports blocked off.
- Gottolovem
What are the requirements in your state?
How bad did your car fail?
You might consider a weber swap!
Your vac system is ugly I'd do the webber"less vac stuff"
What exemptions does you state have?
A webber can usually pass the sniff test but if the smog tec is persnickety it will never pass the visual inspection cuz the system is considered "tampered" with.
