parts car
obeastoyota
My tercel:: 1981 2 door 2wd
parts car
Post by obeastoyota »
I have 1981 2 door 2wd tercel that has the 3ac motor that runs strong and a good 4 speed transmission. I compression tested each cylinder at 180 psi. I believe that it has some of the same parts as the 4wd version. If there is any interest, I will post pictures and answer questions
Mark
Re: parts car
Post by Mark »
If it runs fine why not sell it complete as a running car? The 1st gen Tercels are getting even rarer than the 2nd gen wagons (at least up here).
BrownBadger
My tercel:: 83 4WD Tercel SR5 - The Brown Badger
Re: parts car
Post by BrownBadger »
Where are you?
Re: parts car
Post by irowiki »
Yeah there's still demand for the 1st gen tercels as a collector's item as they are unique and getting rarer!
Where are you located?
4doorVIP
My tercel:: 1988 SR5 Wagon
Re: parts car
Post by 4doorVIP »
sounds great is the carb in good condition?
2JZGTE-powered Tercel SR5
obeastoyota
Re: parts car
Sorry I haven't responded- I thought I had email notifications.I would love to sell it as a whole car however, I have had no luck here in Spokane, Wa. And while the motor runs good (and the carburetor works fine), it needs both cv axles, all new struts, new strut mounts under the hood, and the rear control arms are rusted through in spots. Also the body is pretty rough and the passenger window is broken (has plexi glass instead)
Re: parts car
to get email notifications, click on your username in the top right corner of the screen. from the drop down menu, select user control panel. at the panel, select the 'board preferences' tab. under that tab, select 'edit notification options.' here you can select email notifications for replies to threads you comment on, private messages, etc.
obeastoyota
Re: parts car
dlb wrote:to get email notifications, click on your username in the top right corner of the screen. from the drop down menu, select user control panel. at the panel, select the 'board preferences' tab. under that tab, select 'edit notification options.' here you can select email notifications for replies to threads you comment on, private messages, etc.
Thank you
4wdEconoBox
My tercel:: 1985 Toyota Tercel SR5 4WD
Re: parts car
Post by 4wdEconoBox »
How much for the engine?
