Carb replacement
- My tercel:: 1987 Toyota Tercel SR5
Carb replacement
Anybody know of a good cheap carb? I have to replace mine now.. pain in the ass to find one under $150 that adds power and keeps the same fuel economy.
- My tercel:: 83 4WD Tercel SR5 - The Brown Badger
Re: Carb replacement
I have a known good used weber carb that I'll sell you for $125 with the afapter and short air filter.
Will it fit a 87?
what's wrong with your carb, twamble?
One of my seals on the carb blew off where it pumped the gas and now it's blowing gas everywhere and I don't want to fix that.
- Gottolovem
I will sell you a pick&pull carb for 50 bucks no guarantees on mpg but it wont leak gas all over everything.
What kind of carb is it?
- Gottolovem
Oem carb direct replacement.
the webber will provide a little more power and some say better mpg but their will be a few modifications you will need to make and if there is emissions testing in your area you run the risk of not passing smog.
what I'm offering is just another carb like the one already on your car but it won't leak.
the fuel economy is poor on the weber unless you take the time to experiment with different fuel and air jets. after buying a number of jets to try out, and eventually coming up with a combination that works well and does not give you any flat spots or drivablity issues, you might get the same fuel economy as a properly running OEM factory carb.
Some get lucky and what ever jets it comes with works okay, but I would not count on it.
It is always best I think to fix the factory carb, and get the fuel system to operate properly. Quite often people think they have a carb problem and find that it was not the carb but one of the many other systems that made it run poorly or get poor fuel economy. this is why it is very important, and always best, to make sure you diagnose the problem BEFORE you try and fix it!
Well I'm from Missouri, so how can I buy it and you send it lol
- Gottolovem
Send me a pm with address and we can go from there
@ Twamble - Essex? I'm in Kirkwood, a 'burb of STL! You're just a little West of Sikeston, right?
As to the Weber - I would dispute Petros' comment about "the fuel economy is poor on the weber unless you take the time to experiment with different fuel and air jets. after buying a number of jets to try out, and eventually coming up with a combination that works well and does not give you any flat spots or drivablity issues, you might get the same fuel economy as a properly running OEM factory carb."
I installed the Weber back in 2008 and have experienced the same economy as the OE Aisan - and without any of the emissions drama associated with the latter. I used the same jets as supplied from the vendor.
I am not subject to the emission standards imposed on the STL area, since Goldie is pre-1996. Anyway, your rural area has never had any emission restrictions.
The advantages with the Weber are no tubing or emission devices of any kind, leading to fewer (aka none) of the probs with the vac leaks and emission devices breaking down (or AAP probs). The fuel economy is the same and there is possibly a tad more power.
Yeah just a little west of sikeston! Lol I was thinking about buying a brand new weber 2 barrel carb for 290 on eBay but I was going to look before I actually bought it
I have a number of friends in Sikeston from BMX days at its old Cottonmouth BMX track in the '80's.
One of my two broken collarbones was from that track.
Tom, that may have been your experience with your weber, good for you. but that is not what I have experienced with the Tercel I bought from Forum member Danzo, who had installed the weber from a kit. Jets were all wrong, it ran with flat spots (jurky) and got very poor economy on the drive back. I experimented with a jet kit and made it much more drivable, and improve the economy to about what the factory carb would do. Of course that was a lot simpler than messing with a mass of vac lines and emissions components, but wish I had done that before I took it on a 4000 mile drive (it was okay at hwy speeds, but heavy traffic in Phoenix was a real PIA with several flat spots on the throttle). I have also known there are several others that have put webers on their Tercels and found the same thing.
So either you got lucky, or whoever you bought the kit from knew what to jets to install on yours so it would run good on the Tercel. I do not know how common that is, you may indeed be lucky, or it is just random if it works out okay or not. but I had to change out all of the main, idle and air jets to get it start and run smoothly and get good economy. Power was a bit higher, but it was not any barn burner either.
