The photo is pretty self-explanatory. I would suggest all check their cover. I replaced several bolts and filled the groove when doing the water pump and had the radiator out, so access was improved.
Left-click to enlarge.
Upper Timing Cover Bolts
Re: Upper Timing Cover Bolts
the lower left bolt is easy to reach if you remove the water pump pulley (just 3 10mm bolts holds the the pulley on to the water pump flange).
I did - in fact, I had the pulley off and the radiator out and it was still a female dog.
