I just replaced the PCV and its grommet and, being a good T4WD steward (aka packrat), did not discard the old grommet.
I noticed the hood lift rod grommet had mostly perished and the rod rattled, so - Hmmm...
It worked out great - in fact, better than the OE, as there is now more rubber on both the outside and the inside of the metal body member than before.
It did take a bit of persuasion from silicone spray and nudging with a small flat blade screwdriver, but it finally fit just fine.
Incidentally, the old grommet is also a perfect fit for the hold-downs for the air cleaner tabs to the cam cover on the OE aircleaner.
Left-click to enlarge
PCV Grommet = Hood Rod Grommet
Re: PCV Grommet = Hood Rod Grommet
that is brilliant! I have been meaning to try and find a replacement for all of my T4wd (I am back up to 4 now), all of my hood support rod gromments are gone, looks like that will do it! Great discovery.
Thenk yew, thenk yew, thenk yew verra much...
Incidentally, if you have to buy one, the # is Dorman PCV grommet #42058.
I'll have to order a bunch next time I rockauto. Thanks Tom!
